Question about migrating Z-wave
Good afternoon,
I have a hopefully quick/easy question. I’m planning on migrating my Home Assistant to new hardware. I plan on using the same Aeotec Z-Wave stick, and the plan is to restore my HA backups to the new hardware. Do I need to do anything special to ensure my z-wave is migrated to the new hardware?
Should work. But you will need to check if you have the correct serial port after restore
It is possible, and pretty straightforward. If you use zwave-ui you should let it make backups for settings and nvram and store them in a safe place just to be sure. You should do this anyway periodically. They are not needed for restore, unless something goes wrong.
