I have a unified setup for my bedroom TV which includes a digital mixer. The mixer runs on CAT5 or WiFi connection. Because of logistics, I cannot run a cable to my bedroom; thus, connection is by WiFi, which takes 15-30s to connect after power is applied. Since there is no point in completing the script until the mixer is connected, I have a while loop in my script to check for the mixer (code shortened to highlight the issues):
mbr_rem_turn_on_tv:
alias: MBR REM > Turn on TV
sequence:
# run some tasks
- action: input_select.select_first
data: {}
entity_id:
- input_select.bedroom_eq
- input_select.bedroom_pad
- action: switch.turn_off
data: {}
entity_id: switch.mbr_ps_mp3_audio
- action: switch.turn_on
data: {}
entity_id: switch.mbr_ps_xr12_mixer
# wait for the mixer to go live
- repeat:
while:
- condition: template
value_template: "{{ is_state('number.mbr_mixer_scene_current', 'unavailable') }}"
sequence:
- delay: "00:00:01"
# then do the rest of the tasks
- action: remote.send_command
num_repeats: 1
command: power
entity_id: remote.master_br_roku
etc.
Here’s what happens:
If I call the script directly – ex: using a button to performa a call-service in custom:button-card – script.mbr_rem_turn_on_tv works perfectly, every time.
I want to add a sequence that turns on the TV when I press I button for Netflix, YouTube, etc. and the TV is off. If I call the script from inside another script, though, (see below) the While loop appears to only execute 1-2x, then carries on as if the mixer was connected (it is not) and completes the rest of the code.
mbr_rem_roku_shell_4:
alias: MBR REM > Call Roku App4
description: Turn on TV + Netflix
mode: single
sequence:
- service: script.turn_on
entity_id: script.mbr_rem_turn_on_tv
- delay:
seconds: 3
entity_id: script.mbr_rem_roku_app4
Thanks for the tip. wait_template is a simpler approach … but the end result is the same. The script works perfectly when called directly. It drops through early if called from another script.
OK, I finally got it to work! There was something going with the two scripts executing in parallel – or nearly so – even though I used mode: single. I tried mode: queued which made things better, but not quite right. Maybe adding an if/then made things worse??
At any rate, this approach worked:
mbr_rem_roku_shell_1:
alias: MBR REM > Call Roku App1
description: Turn on TV + BritBox
sequence:
- service: script.mbr_rem_turn_on_tv
- wait_template: "{{ is_state('script.mbr_rem_turn_on_tv', 'off') }}"
- service: script.mbr_rem_roku_app1
mode: single
I don’t know if I needed the wait_template, but it provides insurance. I then moved the if/then/else test to custom:button-card –
The wait_template with a timeout is definitely the way to go for waiting for a power on cycle to land a WIFI connection, 2 actions below where NathanCU’s link lands you in the docs. personally I add a short delay after since I found that sometimes the next action can run before it’s fully set up.
Equally important is understanding the difference between the 2 different ways to call a script as sparkydave points out. script.turn_on will execute and go on to the next action without caring about the script its calling, script.your_script will wait for your called script to complete before moving on tto the next action. Script Integration Docs
