Question about the operation of the LD2410
The problem is that when the sensor is connected via UART to the computer, everything works fine, and GPIO accepts high and low levels according to the sensitivity settings. But if I connect the sensor to an independent power source of +5 volts, without using the computer, then GPIO accepts a high level and does not change. Why? Thank you for your attention
