Running homeassistant (2020.12.2) on docker
I have this automation
blueprint:
name: Presence Automations
description: 'Disable automation(s) when someone arrives. Re-enable them when they
leave.'
domain: automation
input:
person:
description: 'Select the person to be monitored.'
selector:
entity:
domain: person
automation:
description: 'Select the automation(s) that need to be turned off.'
selector:
entity:
domain: automation
inverted:
name: Invert Blueprint
description: 'This will cause the selected automations to enable when the person
comes home, instead of disabling them as per default. This will in turn disable
the automation when the person leaves.'
default: false
selector:
boolean: {}
source_url: https://gist.github.com/dbeltman/b90156effaaa0ea963642334934e541e
- platform: state
entity_id: !input 'person'
condition: []
variables:
inverted: !input 'inverted'
- choose:
- conditions:
- condition: state
state: home
sequence:
- choose:
- conditions: '{{ inverted }}'
sequence:
- service: automation.turn_on
data: {}
target: !input automation
default:
- service: automation.turn_off
data: {}
- conditions:
- condition: state
state: not_home
sequence:
- choose:
sequence:
data: {}
default:
data: {}
default: []
Which works! However when i change the input identifier from “automation” to “target_automation”, it throws me the following error. I’m doing this to make the input identifier less ambiguous.
Invalid config for [automation]: Missing input target_automation (See /config/configuration.yaml, line 9).
Here is the changed final blueprint which throws the error (so the only difference is prepending “automation” with “target_” on 5 occasions)
blueprint:
leave.'
domain: automation
input:
person:
selector:
entity:
domain: person
target_automation:
selector:
entity:
domain: automation
inverted:
default: false
selector:
boolean: {}
- platform: state
condition: []
variables:
- choose:
- conditions:
- condition: state
state: home
sequence:
- choose:
sequence:
data: {}
target: !input target_automation
default:
data: {}
- conditions:
- condition: state
state: not_home
sequence:
- choose:
sequence:
data: {}
default:
data: {}
default: []
In the docs they give an example as such:
input:
target_light:
description: The lights to keep in sync.
selector:
entity:
domain: light
service: >
{% if trigger.to_state.state == "on" %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
target: !input target_light
Am i missing something?
The doc example is basically what i’m doing,but for automations.
Thanks for your help in advance
