I have a problem with one of the zigbee valves I use, sometimes the target temp setting is not applied. I’ve created the following two scripts that call each other (entry point is an automation calling the check script).
Is this script syntax correct? I’m not 100% sure about script.turn_on, is this the way to trigger a script?
Is this the way to do such things in a loop? Is there a better way to get to behaviour of a ‘do while’ loop?
'radiator_veranda_check_high':
alias: Radiator Veranda Check High
sequence:
- below: '18'
condition: numeric_state
entity_id: sensor.radiator_veranda_target_temperature
- delay: 00:00:05
- data:
entity_id: script.radiator_veranda_set_high
service: script.turn_on
'radiator_veranda_set_high':
alias: Radiator Veranda Set High
sequence:
- data:
entity_id: climate.spirit_veranda
temperature: 19.5
service: climate.set_temperature
- delay: 00:00:05
- data:
entity_id: script.1576930646356
Thanks!
