Question on ZHA checkin events
I am suddenly getting a LOT of checkin events fired through ZHA. Below is an example. How can I turn these off, and should I?
Thanks.
Wondering the same thing
Im getting the same with a single device
I’m getting the same spam with a multisensor - zhaquirks.samjin.multi2.SmartthingsMultiPurposeSensor2019
I haven’t seen anything I could do to turn these log entries off? Or at least hide them?
There are several of us wondering the same
I found an answer there : ZHA - Checkin Event was fired ever feww seconds · Issue #85342 · home-assistant/core · GitHub
Sorry Phillip, that doesn’t help me at this time.
I’m still getting the events, about every minute or so. When I try following the directions of pull attrib, when I click the read attribute, it runs for a few secs, then gives me a red stopsign-looking icon for a couple seconds, and never fills in the value.
I have a HUB-z controller plugged into my Odroid N2+.
This is still happening. It started maybe within a month or so of me posting, one of the updates. If I look in the logbook for any of the device/entities, it doesn’t show any checkin event/attribute event, anything, so apparently it is not an entity. Anyone still looking into this?
Please help! My logbook is full of these. It’s nearly impossible to find certain logs because of all of these events firing.
If you still have an issue: Re-configuring the entity with reporting issues fixed the issue for me. I can see you have multiple entities, but I think you could try it anyways. Could be that an update of ZHA caused this…
I think so. I’m having more ZHA problems now, at least with a battery card, but the issue is still here, as I posted the pic above.
My heater valve does the same thing. However, I don’t care about the logbook. My problem is that the LED lights turn on every time this happens… Any way to fix the root cause on the device? (I know this rather a Zigbee problem than HA but I am interested anyway.)
Still no input from devs? I’m seeing the same thing and would love to know why and what I should do about it
Hi! I have recently encountered the same problem. I have 6 leak sensors, which are identified as Sonoff SNZB-03. They all work properly, react to leak events. But about every hour I see the event “Checking event was fired” on three of them. The signal level is sufficient and the power supply is stable. But for some inexplicable reason I can’t get rid of these events.
I have already tried:
  1. Changing the interval PollControl >> checkin_interval. but I can’t read the attribute value or change it, getting an error.
  2. I tried resetting the sensors and setting them up again by deleting them from Home Assistant, sending them the attribute “reset_fact_default”. But it didn’t work.
  3. I checked the power supply of the sensors, put them in close proximity to the ZigBee Home Assistant transmitter and powered them from a lab power supply with 3v. The events continued to bother me.
Any ideas on how to fix this?
I am having a similar issue with Sonoff SNZB-05P Leak Sensor. The SNZB-03 I believe, is a motion sensor. The first time it took for several minutes to complete the configuration. The second time I re-paired it I, i paired it to a local repeater and not the hub. Once it showed Configuring I would briefly tap the Reset/Pair button to keep it alive until it completed configuring. It is no longer doing the CheckIn but I did get a couple of Warnings today in Homeassistant.log about checkin but it didn’t identify the device. I like the build on these sensors and hope the problems can be sorted out.
If I understand correctly, these warnings are caused by the availability check interval being too short for battery-powered devices. Devices should periodically (I’m not sure how often) send an “alive” packet to notify the server that they are still online, their batteries haven’t died, and the network hasn’t been lost. For battery-powered devices, this interval is very long. For example, I noticed that my leak detectors contact the server about once a day. Try increasing the availability check interval to 24 or 48 hours.
For me, this solved the problem with the leakage sensors, as well as with several temperature sensors.
