Question regarding platform state trigger
I’m doing an automation, and I want to know what entity_id caused the automation to trigger:
Here’s an example:
- alias: "Door Meta Sensor"
    - platform: state
      entity_id: binary_sensor.door_window_sensor_158d0001d63b07, binary_sensor.door_window_sensor_158d0001ef77d8, binary_sensor.door_window_sensor_158d0001fa792d
    - service: variable.set_variable
        variable: door_meta
        value_template: '{{ the entity_id from above that just triggered the automation }}'
I could just use an if, elif, elif, else statement for all the sensors, but I’m wondering if there is a cleaner way?
Thanks!
I use this:
{{ trigger.to_state.attributes.friendly_name }}
e.g.
  - service: notify.all_ios_devices
    data_template:
      message: "The {{ trigger.to_state.attributes.friendly_name }} Smoke Alarm has TRIGGERED!!!"
        push:
          badge: 0
          sound: "SmokeDetected.wav"
          category: "silencealarm"
        action_data:
          entity_id: group.alarm_outputs
Hmmm I’m still having some problems, see the below example automation.
- alias: "01 First trigger"
    - platform: state # Door and window
      entity_id: binary_sensor.door_window_sensor_158d0001d63b07, binary_sensor.door_window_sensor_158d0001ef77d8, binary_sensor.door_window_sensor_158d0001fa792d, binary_sensor.door_window_sensor_158d0001a94c35, binary_sensor.door_window_sensor_158d0001f9e2e2, binary_sensor.door_window_sensor_158d0001f38b1f
      to: 'on'
    - platform: state # Motion
      entity_id: binary_sensor.motion_sensor_158d0001e57659, binary_sensor.motion_sensor_158d0001e52dee, binary_sensor.motion_sensor_158d0001dc7526
      to: 'on'
    - service: input_text.set_value
      data_template:
        entity_id: input_text.alarm_trigger_one
        value_template: '{{ trigger.to_state.attributes.friendly_name }}'
        variable: alarm_triggerone
    - service: notify.html5
      data_template:
        message: 'Alarm has been tripped by {{ trigger.to_state.attributes.friendly_name }}'
          tag: 'notification-about-sensor'
The value_template for the notification works great and shows the correct sensor name … however I’m unable to use value_template to store the triggering sensor name into either a ‘variable’ or ‘input_text’.
ok i got it working for input_text
  data_template:
    value: '{{ trigger.to_state.attributes.friendly_name }}'
but not for set variable component
  data_template:
I haven’t used the variable component, but I was just browsing what I believe to be the code for that component. If it is, and I read it correctly, then I think you need to do this:
Also, in your original post, you said you wanted the entity_id of the the entity that caused the trigger. If so you should use trigger.entity_id instead of trigger.to_state.attributes.friendly_name.
And lastly, in your more recent post you showed the triggers as:
      to: 'on'
      to: 'on'
You could put them all in one trigger like this:
    - platform: state
      entity_id:
        - binary_sensor.door_window_sensor_158d0001d63b07
        - binary_sensor.door_window_sensor_158d0001ef77d8
        - binary_sensor.door_window_sensor_158d0001fa792d
        - binary_sensor.door_window_sensor_158d0001a94c35
        - binary_sensor.door_window_sensor_158d0001f9e2e2
        - binary_sensor.door_window_sensor_158d0001f38b1f
        - binary_sensor.motion_sensor_158d0001e57659
        - binary_sensor.motion_sensor_158d0001e52dee
        - binary_sensor.motion_sensor_158d0001dc7526
      to: 'on'
But this is more of a style suggestion than anything.
I agree with @pnbruckner. {{ trigger.entity_id }} is what you want for the entity id out of a trigger. attribute.friendly_name will give you the name that is shown in the UI. All of those attributes for triggers are in the automation templating documentation. Hopefully this will help you so you aren’t taking a stab in the dark when trying to find crap inside triggers:
