Result:
I bought the HA Green, and the setup was seamless using a backup from my old HA server. After restoring the backup, all my automations and devices from various integrations worked instantly on Green.
All but the zigbee devices, because I wanted to switch from zha to z2m I did not connected the skyconnect stick to the Green. In hindsight, it would have been interesting to test whether ZHA and the Zigbee devices would have worked just as instantly on the new HA Green setup.
Since I wanted to transition gradually from the old to the new server, I purchased a new Zigbee controller (SLZB-06). Initially, I planned to switch from ZHA (old server) to Z2M (HA Green) step by step. However, connecting all my Zigbee devices with z2m was so easy that I ended up migrating everything within a few hours. Pairing worked significantly better with Z2M, most devices paired on the first attempt, whereas in ZHA, it often took multiple tries. I’m not sure if Z2M has a better pairing mechanism or if the SLZB-06 is simply superior to the SkyConnect.
The only challenge was connecting the SLZB-06. I initially wanted to use it via USB, but after two hours of troubleshooting, it became clear that the SLZB-06 does not work in USB mode with HA Green due to requiring special USB drivers. In the end, I set it up via Ethernet, which works perfectly, though it required an additional Ethernet cable and a USB power adapter.
According to my smart plug, HA Green consumes an average of 1.1W. Thats around 25-27W less than my old HA server and there seems to be no difference in speed or reaction times. CPU-Usage of the Green is around 3%, RAM usage 40%.
ZHA vs. Z2M:
I am very pleased with Z2M. It seems more stable than ZHA and supports additional features on some devices. For example, I can now use two Green Power devices (old Hue Tap) without issues, whereas ZHA does not support them. Additionally, I can set gradient colors on my Hue Gradient Lightstrip, whereas ZHA only allowed a single color and z2m provides some other effects like candle or fireplace (at least for some hue devices) that I knew from the hue app but vanished after dumping hue and connecting the devices via zigbee.
Even though I installed ZHA-tools on my old HA server, ZHA never discovered updates for any of my Zigbee devices. In contrast, Z2M immediately found updates for all my devices, including some critical updates for my window covers that supposedly improve battery efficiency. Some updates took hours to install, but now all my devices are running the latest firmware, and some seem to perform better as a result.
The only thing that slightly bothers me is that HA still displays the SkyConnect stick on the hardware page, even though it’s not connected and it cannot be removed. It seems to be a leftover from the restored backup.
Conclusion:
Switching to HA Green was quick and straightforward. The most time-consuming challenges were dealing with the unexpected USB issues of the new device (SLZB-06, that is working good otherwise) and pairing over 50 Zigbee devices.
