Heres when I set it to 75:
2018-12-14 09:13:38.640 Info, Node009, Value::Set - COMMAND_CLASS_THERMOSTAT_SETPOINT - Unused 3 - 3 - 1 - 75
2018-12-14 09:13:38.640 Detail, Node009, Queuing (Send) ThermostatSetpointCmd_Set (Node=9): 0x01, 0x0c, 0x00, 0x13, 0x09, 0x05, 0x43, 0x01, 0x03, 0x01, 0x4b, 0x25, 0x63, 0xa1
2018-12-14 09:13:38.640 Detail, Node009, Queuing (Send) ThermostatSetpointCmd_Get (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x43, 0x02, 0x03, 0x25, 0x64, 0xef
2018-12-14 09:13:38.641 Detail,
2018-12-14 09:13:38.641 Info, Node009, Sending (Send) message (Callback ID=0x63, Expected Reply=0x13) - ThermostatSetpointCmd_Set (Node=9): 0x01, 0x0c, 0x00, 0x13, 0x09, 0x05, 0x43, 0x01, 0x03, 0x01, 0x4b, 0x25, 0x63, 0xa1
2018-12-14 09:13:38.651 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-14 09:13:38.651 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-14 09:13:40.062 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x63, 0x00, 0x00, 0x8e, 0x06
2018-12-14 09:13:40.062 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x63 received (expected 0x63)
2018-12-14 09:13:40.062 Info, Node009, Request RTT 1421 Average Request RTT 1569
2018-12-14 09:13:40.062 Detail, Expected callbackId was received
2018-12-14 09:13:40.062 Detail, Expected reply was received
2018-12-14 09:13:40.063 Detail, Message transaction complete
2018-12-14 09:13:40.063 Detail, Node009, Removing current message
2018-12-14 09:13:40.063 Info, Node009, Sending (Send) message (Callback ID=0x64, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x43, 0x02, 0x03, 0x25, 0x64, 0xef
2018-12-14 09:13:40.072 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-14 09:13:40.072 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-14 09:13:40.191 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x64, 0x00, 0x00, 0x0d, 0x82
2018-12-14 09:13:40.191 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x64 received (expected 0x64)
2018-12-14 09:13:40.191 Info, Node009, Request RTT 128 Average Request RTT 848
2018-12-14 09:13:40.191 Detail, Expected callbackId was received
2018-12-14 09:13:50.064 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-12-14 09:13:50.064 Detail, Node009, Removing current message
2018-12-14 09:13:50.065 Detail, Node009, Notification: Notification - TimeOut
Heres when I change the operation mode successfully:
2018-12-14 09:17:38.774 Info, Node009, Value::Set - COMMAND_CLASS_THERMOSTAT_MODE - Mode - 0 - 1 - Off
2018-12-14 09:17:38.774 Detail, Node009, Queuing (Send) ThermostatModeCmd_Set (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x40, 0x01, 0x00, 0x25, 0x6d, 0xe5
2018-12-14 09:17:38.774 Detail, Node009, Queuing (Send) ThermostatModeCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x40, 0x02, 0x25, 0x6e, 0xe7
2018-12-14 09:17:38.775 Detail,
2018-12-14 09:17:38.776 Info, Node009, Sending (Send) message (Callback ID=0x6d, Expected Reply=0x13) - ThermostatModeCmd_Set (Node=9): 0x01, 0x0a, 0x00, 0x13, 0x09, 0x03, 0x40, 0x01, 0x00, 0x25, 0x6d, 0xe5
2018-12-14 09:17:38.785 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-14 09:17:38.786 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-14 09:17:40.174 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x6d, 0x00, 0x00, 0x8b, 0x0d
2018-12-14 09:17:40.175 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x6d received (expected 0x6d)
2018-12-14 09:17:40.175 Info, Node009, Request RTT 1398 Average Request RTT 1123
2018-12-14 09:17:40.175 Detail, Expected callbackId was received
2018-12-14 09:17:40.175 Detail, Expected reply was received
2018-12-14 09:17:40.175 Detail, Message transaction complete
2018-12-14 09:17:40.175 Detail, Node009, Removing current message
2018-12-14 09:17:40.176 Info, Node009, Sending (Send) message (Callback ID=0x6e, Expected Reply=0x04) - ThermostatModeCmd_Get (Node=9): 0x01, 0x09, 0x00, 0x13, 0x09, 0x02, 0x40, 0x02, 0x25, 0x6e, 0xe7
2018-12-14 09:17:40.185 Detail, Node009, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-12-14 09:17:40.186 Detail, Node009, ZW_SEND_DATA delivered to Z-Wave stack
2018-12-14 09:17:40.242 Detail, Node009, Received: 0x01, 0x07, 0x00, 0x13, 0x6e, 0x00, 0x00, 0x06, 0x83
2018-12-14 09:17:40.242 Detail, Node009, ZW_SEND_DATA Request with callback ID 0x6e received (expected 0x6e)
2018-12-14 09:17:40.243 Info, Node009, Request RTT 66 Average Request RTT 594
2018-12-14 09:17:40.243 Detail, Expected callbackId was received
2018-12-14 09:17:40.999 Detail, Node009, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x09, 0x03, 0x40, 0x03, 0x00, 0xbb
2018-12-14 09:17:40.999 Info, Node009, Response RTT 823 Average Response RTT 553
2018-12-14 09:17:40.999 Detail, Node009, Refreshed Value: old value=1, new value=0, type=list
2018-12-14 09:17:41.000 Detail, Node009, Changes to this value are not verified
2018-12-14 09:17:41.000 Info, Node009, Received thermostat mode: Off
2018-12-14 09:17:41.000 Detail, Node009, Expected reply and command class was received
2018-12-14 09:17:41.000 Detail, Node009, Message transaction complete
2018-12-14 09:17:41.001 Detail, Node009, Removing current message
2018-12-14 09:17:41.001 Detail, Node009, Notification: ValueChanged
