Dears,
I have and ESP32 to manage the wind speed with an anemometer and a rain detector.
The Rain detector is based on the following system:
https://github.com/hugokernel/esphome-rain-detector
But the code in ESPHome is not working well for me and I want to control the rain detector with node red.
Then, I have only the resistance measure from ESP32 and a switch to activate the resistance measure, because if the panel sensor is wet ant the voltage is active continuously the sensor degrades rapidly by oxidation.
Then I need a flow with the following specifications:
- A general loop each 5 seconds.
- For each loop:
- Activate the switch.
- Read 5 times the resistance and average the results.
- Turn off the switch.
- if the resistance is equal to the max resistance it means that sensor is dry, Alarm_raining = OFF. Then, I need to continue reading new five resistance values to average and have new result. Each loop needs to continue each 5 seconds.
- If the resistance is lower than the max resistance, it means that is raining and I need to change the loop time to 30 seconds and Alarm_raining = ON.
In order to improve the systems can be interesting to know if the sensor is drying o if the sensor is weting, but then I need to know the actual average reading and the latest average value to compare.
I’m newbie about node red and I don’t know how to perform loops with variable time between readings.
Without the average readings this is the first approach using the node “configurable interval” installed:
But the rest of my proposal to average the readings I don’t know how to perform, any help for this please?.
The total code is:
[{"id":"12777efadb3c2970","type":"inject","z":"aa5ee1809b09809f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":150,"y":480,"wires":[["be3f7410cf69a195"]]},{"id":"726a132f8f8e2722","type":"debug","z":"aa5ee1809b09809f","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":600,"wires":[]},{"id":"be3f7410cf69a195","type":"function","z":"aa5ee1809b09809f","name":"InitialSeconds","func":"msg.payload = msg.payload / 1000.0;\nreturn msg;","outputs":1,"noerr":0,"x":320,"y":480,"wires":[["c526925f2f36c672"]]},{"id":"c526925f2f36c672","type":"change","z":"aa5ee1809b09809f","name":"SetFlowInitial","rules":[{"t":"set","p":"dbgtimer","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"enabled","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":480,"wires":[["161afa8ff3bb7541"]]},{"id":"161afa8ff3bb7541","type":"configurable interval","z":"aa5ee1809b09809f","name":"configurable interval","interval":"5","onstart":false,"do_enable":true,"msg":"ping","showstatus":true,"unit":"seconds","statusformat":"YYYY-MM-D HH:mm:ss","x":720,"y":480,"wires":[["9436e25edfc2798a"]]},{"id":"693b135635d313aa","type":"api-current-state","z":"aa5ee1809b09809f","name":"","server":"f6976039.c880a","version":3,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"lte","entity_id":"sensor.rain_detector_resistencia","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":360,"y":620,"wires":[["682649701f20b085","726a132f8f8e2722"]]},{"id":"9436e25edfc2798a","type":"api-call-service","z":"aa5ee1809b09809f","name":"Switch Bias Voltage ON","server":"f6976039.c880a","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.rain_detector_resistance_bias"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":970,"y":480,"wires":[["2ed6d6eb2ea0360b"]]},{"id":"2ed6d6eb2ea0360b","type":"delay","z":"aa5ee1809b09809f","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1180,"y":480,"wires":[["693b135635d313aa"]]},{"id":"80b67dbd7412f945","type":"api-call-service","z":"aa5ee1809b09809f","name":"Switch Bias Voltage OFF","server":"f6976039.c880a","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.rain_detector_resistance_bias"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1110,"y":740,"wires":[[]]},{"id":"682649701f20b085","type":"switch","z":"aa5ee1809b09809f","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"50000","vt":"num"},{"t":"lte","v":"50000","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":410,"y":740,"wires":[["ccf2d7d27d8c57c7"],["e039d315e8977256"]]},{"id":"83bff2e1d8431b1b","type":"change","z":"aa5ee1809b09809f","name":"_30s","rules":[{"t":"set","p":"payload","pt":"msg","to":"interval","tot":"str"},{"t":"set","p":"interval_value","pt":"msg","to":"30","tot":"str"},{"t":"set","p":"interval_unit","pt":"msg","to":"seconds","tot":"str"},{"t":"set","p":"interval_activeInstantly","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"interval_fireInstantly","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":780,"wires":[["80b67dbd7412f945","161afa8ff3bb7541"]]},{"id":"1c5a4fad0d04607d","type":"change","z":"aa5ee1809b09809f","name":"_5s","rules":[{"t":"set","p":"payload","pt":"msg","to":"interval","tot":"str"},{"t":"set","p":"interval_value","pt":"msg","to":"5","tot":"str"},{"t":"set","p":"interval_unit","pt":"msg","to":"seconds","tot":"str"},{"t":"set","p":"interval_activeInstantly","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"interval_fireInstantly","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":720,"wires":[["80b67dbd7412f945","161afa8ff3bb7541"]]},{"id":"e039d315e8977256","type":"change","z":"aa5ee1809b09809f","name":"on","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":780,"wires":[["7c50ccf2b65edf32"]]},{"id":"ccf2d7d27d8c57c7","type":"change","z":"aa5ee1809b09809f","name":"off","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":720,"wires":[["e2a537f4f2f2ff49"]]},{"id":"e2a537f4f2f2ff49","type":"api-call-service","z":"aa5ee1809b09809f","name":"Rain Alarm OFF","server":"f6976039.c880a","version":5,"debugenabled":true,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.10_alarma_lluvia"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":740,"y":720,"wires":[["1c5a4fad0d04607d"]]},{"id":"7c50ccf2b65edf32","type":"api-call-service","z":"aa5ee1809b09809f","name":"Rain Alarm ON","server":"f6976039.c880a","version":5,"debugenabled":true,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.10_alarma_lluvia"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":740,"y":780,"wires":[["83bff2e1d8431b1b"]]},{"id":"f6976039.c880a","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
Thanks in advance.
Jose
