tom_l
March 2, 2025, 12:13am
1
I recently installed a tipping bucked rain gauge with 0.2mm resolution (per tip) to my garden ESP32.
I’ve checked the pulse output from the gauge, very clean (no debouncing needed) with a negative going ~50ms pulse per tip.
I’ve implemented this sensor config:
- platform: pulse_counter
pin:
number: GPIO21
inverted: true
mode:
input: true
pullup: true
count_mode:
rising_edge: DISABLE
falling_edge: INCREMENT
unit_of_measurement: 'mm/h'
device_class: precipitation_intensity
state_class: measurement
icon: "mdi:speedometer"
update_interval: 15min
filters:
- multiply: 0.8 # 0.2mm per pulse for 1/4 hour
total:
unit_of_measurement: 'mm'
state_class: total
icon: "mdi:weather-pouring"
filters:
- multiply: 0.2
Questions:
Have I got the rain rate filter correct?
0.2mm per tip, updated every 15 minutes (for better accuracy), gives 0.2 * 4 = 0.8 for the unit of mm/h. Correct?
Why is the total not updating?
Last night there was a short shower. it registered 0.05mm/h but no total update:
A nearby weather station (BoM) recorded 0.4mm.
The reported 0.05mm/h rain rate means there were:
0.05/0.8 = 0.0625 tips which is just wrong.
Interestingly if I multiply that by 15 it comes out damn near 1.
Does the pulse counter automatically divide the reading by my update interval and assume I want a /minute output?
That seems very counter intuitive.
zoogara
(Daryl)
March 2, 2025, 12:30am
2
Does the pulse counter report pulses per minute, same as the newer pulse meter? I thought the major difference was the new one was more accurate.
Would that make sense compared to your thinking that it reports number of pulses per interval?
tom_l
March 2, 2025, 12:33am
3
I assumed this would take precedence:
tom_l:
Now I’m thinking that this is just how often the sensor reports to HA and it always uses a /min rate.
This would be bad. Tipping bucket rain gauge rain rate accuracy improves with sample time. 1min is awful, 10min is acceptable, but I can no longer find the paper where I read this.
I just removed all filters, rebuilt and went and squirted enough water into the gauge to tip once. Still have 6 minutes until I get a result…
tom_l
March 2, 2025, 12:46am
4
Ok results are in for no filters, 15 minute interval, after applying 0.2mm of rainfall:
Total: 1mm: → I must multiply by 0.2 to get the real value. This was expected (0.2mm/tip).
Rate: 0.13 → I would have to multiply by 6.1538 to get 0.8mm/h, I have no idea where this number comes from. Has the /min rate decayed over the 15 minutes between reports?
EDIT: found the paper on accuracy by the way: https://ntrs.nasa.gov/api/citations/20070016690/downloads/20070016690.pdf conclusions are at the bottom of page 28 (pdf numbering), or page 26 (document numbering).
Next I will change the update interval to 1 minute and see what happens.
tom_l
March 2, 2025, 1:09am
5
Curiouser and curiouser.
No filters for the rate, *0.2 for the total, 1 minute interval, after applying 0.2mm of rainfall:
Total: 0 (did not update!)
Rate: 1 (decayed to 0 one minute later).
This does not help me work out where the 6.1538 for 15 minutes comes from.
And the total is back to not updating. Applying a filter to this seems to break it.
This component is busted as.
zoogara
(Daryl)
March 2, 2025, 1:18am
6
Time to try Pulse Meter instead of Pulse Counter?
I am not much help here - I use an Ecowitt weather station via 433MHz and their own gateway…
tom_l
March 2, 2025, 3:48am
7
Nah the counter was the correct one. The pulse meter only counts per minute.
With the help from the knowledgeable folks over on the esphome Discord I got it sorted.
If multiplying the total by 0.2 I have to set the accuracy_decimals: 1 option. The total counter has a default accuracy of 0 decimals.
Calculating the rate should have been:
multiply: 12 # 5 pulses/mm in 15 minutes = *3 for mm/15min, but I want mm/h so *4 as well
Final config:
pin:
number: GPIO21
# inverted: true
mode:
input: true
pullup: true
count_mode:
accuracy_decimals: 4
filters:
- multiply: 12 # 5pulses/mm in 15 miunutes = *3, reported as mm/h every 15 minutes = *4
total:
state_class: total
filters:
- multiply: 0.2
Finally and most importantly, note also that there is another issue. The first counter period after a restart is not guaranteed to be 15 minutes . This is what was sending my numbers all over the place. This random interval is so that all sensors don’t update at the same time.
uss
September 11, 2025, 8:46am
8
To solve the first counter problem, I’ve done:
globals:
- id: rain_ready
type: bool
restore_value: false
initial_value: 'false'
# Rain gauge pulse sensor
pin:
number: GPIO4
mode:
input: true
pullup: true
count_mode:
rising_edge: INCREMENT
falling_edge: DISABLE
internal: true
update_interval: 60s
filters:
- multiply: 0.3 # each pulse = 0.3 mm of rain
- platform: integration
sensor: rain_raw
time_unit: min
integration_method: right
restore: false
internal: true
on_value:
then:
- lambda: |-
if (!id(rain_ready)) {
id(daily_rain_internal).reset();
id(rain_ready) = true;
# Public template sensor: exposes value after id(rain_ready) is true
name: "Daily Rainfall"
unit_of_measurement: "L/m²"
state_class: total_increasing
lambda: |-
if (id(rain_ready)) {
// return the internal integration value once we're initialized
return id(daily_rain_internal).state;
// unavailable until first interval is discarded
return NAN;
tom_l
September 11, 2025, 8:52am
9
It’s not really a problem that needs solving for me. The chances of me resetting the ESP when it is raining are vanishingly small. It was only an issue when I was testing to get the filter right.
Wawa
(Leo)
January 21, 2026, 11:11pm
10
tom_l:
Pulses are integers.
This line could use floating point calculations.
I had some random jumps of 0.4mm until I removed this line.
tom_l
January 22, 2026, 1:18am
11
Wawa:
The pulse counter component reports a rate (pulses per unit time) which is a floating point number, not an integer.
Wawa
(Leo)
January 22, 2026, 8:15pm
12
I still get decimal places with that line removed, same as with that line.
Only the weird jumps are gone.
New to Yaml, where the actualcode is hidden. I would understand behaviour better in C++.
But never mind, it seems to work better for me with the line removed
