I recently got an older RainMachine that was made in 2014, with the assumption that it would work with Home Assistant. However, I’ve tried configuring it through both YAML and the UI, and neither seem to work. Here is the YAML that I am using
rainmachine:
controllers:
- ip_address: 0.0.0.0
port: 80
ssl: false
password: password
# Scan Interval set ridiculously low while testing
scan_interval: 1
Additionally, I’ve tried using both a hostname and IP address. It’s also my understanding that the original units only communicate 80 & 443, but the local UI never works over HTTPS, so I have tried to stick with HTTP.
Here is some additional information from the UI which lists the firmware, hardware, and API versions.
Firmware version
3.80 (No updates)
Hardware revision
1
API
3.64
There also isn’t a single mention of ‘rainmachine’ in my logs, so I have no idea what the issue is.
Does anybody have any ideas?
