Very new to all this. Tying to bind a faked remote to a Nuaire PIV. PIV in binding mode and running the action as below:-
action: ramses_cc.bind_device
device_id: 32:111111
offer:
22F1: null
10E0: null
device_info: ' I --- 32:111111 63:262142 --:------ 10E0 030 000001C85A01016CFFFFFFFFFFFF010607E0564D4E2D32334C4D48323300'
Error reported:
*Failed to perform the action ramses_cc.bind_device. Unexpected error during binding for 32:111111: Fakeable._initiate_binding_process() got an unexpected keyword argument 'ratify_cmd'. Did you mean 'ratify_command'?*
It was suggested that there is an error in a python file. Beyond me.
Any help would be very gratefully received
ramses_rf 0.60.4
System Information
| version | core-2026.9.2 |
| installation_type | Home Assistant OS |
| dev | false |
| hassio | true |
| docker | true |
| container_arch | aarch64 |
| user | root |
| virtualenv | false |
| python_version | 3.14.6 |
| os_name | Linux |
| os_version | 6.18.34-haos-raspi |
| arch | aarch64 |
| timezone | Europe/London |
| config_dir | /config |
Home Assistant Cloud
| logged_in | false |
| can_reach_cert_server | ok |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
HACS
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| GitHub API Calls Remaining | 5000 |
| Installed Version | 2.0.5 |
| Stage | running |
| Available Repositories | 4181 |
| Downloaded Repositories | 5 |
Home Assistant Supervisor
| host_os | Home Assistant OS 18.2 |
| update_channel | stable |
| supervisor_version | supervisor-2026.09.0 |
| agent_version | 1.10.0 |
| docker_version | 29.6.2 |
| disk_total | 219.4 GB |
| disk_used | 20.5 GB |
| nameservers | 81.139.57.100, 192.168.34.254 |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | |
| board | rpi4-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Node-RED (22.0.6), Studio Code Server (7.1.0), Terminal & SSH (10.4.0), Mosquitto broker (7.1.1), Network UPS Tools (0.18.1), Z-Wave JS UI (7.6.0), Home Assistant Google Drive Backup (0.112.1), chrony (6.1.0), Samba share (12.10.0), Let’s Encrypt (6.5.0), OpenThread Border Router (3.1.2), Matter Server (9.2.0) |
