I have been running Ramses_rf in Home Assistant for some months with a Honeywell Evohome system. I am not an IT or coding whizz but found the installation and configuration process logical and successful. Recently I have been trying to integrate a Nuaire PIV system and found the exact opposite. I’ve scoured the forums and Wikis but am floundering. I’m hoping for some guidance.
I’m running Ramses_rf 0.60.4 and Home Assistant core-2026.9.2 . Everything is fully updated as of 15/9/26. The PIV is a DRI-ECO-HEAT-HC Nuaire PIV Unit with Heater & RF.
Ramses has detected a number of IDs from the PIV but I’m afraid I don’t understand them. I have created a dummy remote 32:111111 and put it in the schema. However discovery insists it is a FAN. Also I’m pretty sure 30:080071 is a FAN and have amended the schema accordingly but discovery insists it is a CTL.
Discovery also detected 30:077002 as CTL. I have skipped that for now.
This is the message I get on startup:-
RAMSES CC: Schema mismatches detected
**1 class mismatch(es):**
* 30:080071 — schema=FAN, discovery=CTL
**1 missing \_class:**
* 32:111111 — discovery=FAN
**1 weak signal device(s):**
* 13:001788 — RSSI -77 dBm (weak)
I have not yet been able to bind the faked remote to the fan, awaiting a ramses_rf bug fix, but this confusion will not help I’m sure.
I have cleared the cache and re-installed ramses-rf a couple of times but get the same confusing results. Any guidance to resolve would be very much appreciated.
Here is my current ramses-rf schema with the obvious (to me) Evohome stuff removed.:-
30:077002: >-
Likely CTL. zone 00. codes: 10E0, 1F09, 31D9, 31DA. RSSI -83.
(auto-generated — do not edit)
30:080071: >-
Likely CTL. zone 00. codes: 10D0, 10E0, 1F09, 2411, 3150. RSSI -34.
34:023769: >-
Likely RND (confidence: medium). codes: 30C9. RSSI -65. (auto-generated — do
not edit)
32:111111: >-
Likely FAN. may also be DIS (31DA is sent by both). codes: 2411.
01:213901:
_class: CTL
_owner: me
_name: Hall
12:253992:
_class: THM
_owner: me
_skipped: true
30:077002:
_owner: me
_skipped: true
30:080071:
_bound: 32:111111
_class: FAN
_owner: me
18:104912:
_class: HGI
_owner: me
32:111111:
_owner: me
class: REM
commands:
battery_ok: ’ I — 32:111111 --:------ 32:111111 1060 003 00FF01’
boost: ’ I — 32:111111 30:080071 --:------ 22F1 003 00030A’
get_fan_info: RQ — 32:111111 30:080071 --:------ 31DA 001 00
heater_auto: ’ I — 32:111111 30:080071 --:------ 22F1 003 000A0A’
heater_off: ’ I — 32:111111 30:080071 --:------ 22F1 003 00090A’
normal: ’ I — 32:111111 30:080071 --:------ 22F1 003 00020A’
faked: true
