My HA setup (standard HA OS on RPi4, strong enough power supply) reboots several times per day, and I have not clue how to even debug. I don’t see anything in the log. Also CPU usage seems normal. What could I do to figure out the issue?
ssh [email protected] -p 22222
# uptime -s
2023-03-25 08:03:13
# journalctl --since today
Mar 25 07:49:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T07:49:01.190Z [INFO] HA-WS heart beat result: "pong"
Mar 25 07:49:28 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.H8bfsw.mount: Deactivated successf
ully.
Mar 25 07:49:47 homeassistant addon_core_samba[482]: Registered MSG_REQ_POOL_USAGE
Mar 25 07:49:48 homeassistant addon_core_samba[482]: Registered MSG_REQ_POOL_USAGE
Mar 25 07:49:48 homeassistant addon_core_samba[482]: Could not find child 151 -- ignoring
Mar 25 07:50:40 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.bL3DdW.mount: Deactivated successf
ully.
Mar 25 07:50:58 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.fNHC6t.mount: Deactivated successf
ully.
Mar 25 07:51:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T07:51:01.202Z [INFO] HA-WS heart beat result: "pong"
Mar 25 07:51:41 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.4cCWAD.mount: Deactivated successf
ully.
Mar 25 07:52:59 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.OKzqiC.mount: Deactivated successf
ully.
Mar 25 07:53:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T07:53:01.216Z [INFO] HA-WS heart beat result: "pong"
Mar 25 07:53:29 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.eg0YRO.mount: Deactivated successf
ully.
Mar 25 07:53:53 homeassistant hassio_supervisor[482]:
Mar 25 07:54:13 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.hqsHqL.mount: Deactivated successf
ully.
Mar 25 07:54:44 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.mRPJVP.mount: Deactivated successf
ully.
Mar 25 07:55:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T07:55:01.227Z [INFO] HA-WS heart beat result: "pong"
Mar 25 07:55:04 homeassistant homeassistant[482]: 2023-03-25 08:55:04.375 ERROR (MainThread) [aiohttp.server] Error handling request
Mar 25 07:55:04 homeassistant homeassistant[482]: Traceback (most recent call last):
Mar 25 07:55:04 homeassistant homeassistant[482]: File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 334, in data_received
Mar 25 07:55:04 homeassistant homeassistant[482]: messages, upgraded, tail = self._request_parser.feed_data(data)
Mar 25 07:55:04 homeassistant homeassistant[482]: File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
Mar 25 07:55:04 homeassistant homeassistant[482]: aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'Invalid method encountered'"
Mar 25 07:55:04 homeassistant homeassistant[482]: 2023-03-25 08:55:04.430 ERROR (MainThread) [aiohttp.server] Error handling request
Mar 25 07:55:29 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.2UCz5b.mount: Deactivated successf
ully.
Mar 25 07:56:00 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.KVGqYc.mount: Deactivated successf
ully.
Mar 25 07:56:45 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.a9ip52.mount: Deactivated successf
ully.
Mar 25 07:57:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T07:57:01.240Z [INFO] HA-WS heart beat result: "pong"
Mar 25 07:57:30 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.c1Brto.mount: Deactivated successf
ully.
Mar 25 07:57:46 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.Vz1lYd.mount: Deactivated successf
ully.
Mar 25 07:58:53 homeassistant hassio_supervisor[482]:
Mar 25 07:59:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T07:59:01.254Z [INFO] HA-WS heart beat result: "pong"
Mar 25 08:01:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T08:01:01.268Z [INFO] HA-WS heart beat result: "pong"
Mar 25 08:01:01 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.xzyxGS.mount: Deactivated successf
ully.
Mar 25 08:01:49 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.p8pvaI.mount: Deactivated successf
ully.
Mar 25 08:02:31 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.U0OfEb.mount: Deactivated successf
ully.
Mar 25 08:03:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T08:03:01.282Z [INFO] HA-WS heart beat result: "pong"
Mar 25 08:03:54 homeassistant hassio_supervisor[482]:
Mar 25 08:04:02 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.5QJFNf.mount: Deactivated successf
ully.
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextTyp
e.DNS_SERVER
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTE
M
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/Contex
tType.DNS_SERVER
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/Cont
extType.SYSTEM
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.check] System checks complete
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
Mar 25 08:04:32 homeassistant hassio_supervisor[482]: 23-03-25 09:04:32 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
Mar 25 08:04:47 homeassistant addon_core_samba[482]: Registered MSG_REQ_POOL_USAGE
Mar 25 08:04:48 homeassistant addon_core_samba[482]: Registered MSG_REQ_POOL_USAGE
Mar 25 08:04:48 homeassistant addon_core_samba[482]: Could not find child 153 -- ignoring
Mar 25 08:04:51 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.KBGNki.mount: Deactivated successf
ully.
Mar 25 08:04:58 homeassistant hassio_supervisor[482]: 23-03-25 09:04:58 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Mar 25 08:05:01 homeassistant addon_f4f71350_ewelink_smart_home_slug[482]: 2023-03-25T08:05:01.293Z [INFO] HA-WS heart beat result: "pong"
Mar 25 08:05:32 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-986025af62662e53bc2fe437f1890b0c8ca93197570467753aa093c9fbc57e73-runc.N9tYGA.mount: Deactivated successf
ully.
Mar 25 08:05:52 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.Xjrwbj.mount: Deactivated successf
ully.
Mar 25 08:06:53 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-1485839290a0ea9405632e21a78e316a07233b2d10fd061f86afcbc2fdd1cd67-runc.1fisd2.mount: Deactivated successf
ully.
