Random restarts after re-install on Home Assistant Yellow
Hi all,
I have had issues with my HA instance randomly restarting unprompted on a Home Assistant Yellow since being forced into a complete wipe and reinstall last week. Other than re-using a backup of my ZHA, it is a completely fresh install with a reinstall of all integrations and add-ons. I am running Home Assistant 2023.3.4).
After taking advice, I looked in home-assistant.log.fault and the file is empty. Since looking there at around 11 am yesterday I have taken note of the times of the restarts which I have listed below.
16th March
11:47
13:24
15:07
19:37
17th March
07:37
Currently I am running:
Home Assistant 2023.3.5
Supervisor 2023.03.1
Operating System 9.5
Any help would be greatly appreciated.
Logs needed
I can only find log files after the restart today at 07:38. They start at 2023-03-17 07:45:07.765
2023-03-17 07:45:07.765 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hildebrandglow_dcc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.768 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.771 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration truenas which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.773 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration discord_game which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.775 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.778 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.780 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration circadian_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.782 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration eufy_security which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.784 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.787 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.789 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration powercalc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.791 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration eufy_vacuum which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.793 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.795 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration octopus_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.797 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration skyq which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.799 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.801 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration ui_lovelace_minimalist which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.803 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration huesyncbox which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.805 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration garbage_collection which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.807 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration steam_wishlist which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.809 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration teamtracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.811 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration xmrig which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:07.813 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-03-17 07:45:34.050 WARNING (MainThread) [zhaquirks] Loaded custom quirks. Please contribute them to https://github.com/zigpy/zha-device-handlers
2023-03-17 07:45:34.194 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:45:34.228 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:45:35.274 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:45:35.280 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:45:37.377 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:45:37.417 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:45:38.359 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(MSS420F - Office (4 Gang)) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-17 07:45:38.364 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(MSS420F - Bedroom (4 Gang)) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-17 07:45:38.367 WARNING (MainThread) [custom_components.meross_lan] MerossDevice(MSS210 - Office (Air Purifier)) ServerDisconnectedError(Server disconnected) in async_http_request GET Appliance.System.All
2023-03-17 07:45:41.450 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:45:41.454 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:45:43.035 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x9AB7:2:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.040 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x4AA3:2:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.045 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCEAE:1:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.049 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCEAE:2:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.179 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x9AB7:2:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.182 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x4AA3:2:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.185 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCEAE:1:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:43.188 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCEAE:2:0x0006]: 'async_initialize' stage failed: 'backlight_mode'
2023-03-17 07:45:49.464 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:45:49.469 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:45:52.202 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x8216:1:0x0008]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-03-17 07:45:53.172 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x8216:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>'), DeliveryError('Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>')]
2023-03-17 07:46:01.832 ERROR (MainThread) [custom_components.ui_lovelace_minimalist.base] HACS Frontend repo "weather-radar-card" is not installed, See Integration Configuration.
2023-03-17 07:46:05.508 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:46:05.512 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:46:23.561 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: mqtt, zha
2023-03-17 07:46:31.360 ERROR (MainThread) [custom_components.eufy_vacuum.tuya] Connection to 60303850cc50e3322791 (10.0.1.63:6668) failed: [Errno 104] Connection reset by peer
2023-03-17 07:46:37.519 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:46:37.521 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:46:41.359 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform garbage_collection is taking over 10 seconds.
2023-03-17 07:47:06.514 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.24_binnie_road_smart_gas_meter_cost_today (<class 'custom_components.hildebrandglow_dcc.sensor.Cost'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
2023-03-17 07:47:06.518 WARNING (SyncWorker_0) [urllib3.connectionpool] Connection pool is full, discarding connection: api.glowmarkt.com. Connection pool size: 10
2023-03-17 07:47:06.555 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.24_binnie_road_smart_electricity_meter_cost_today (<class 'custom_components.hildebrandglow_dcc.sensor.Cost'>) is using state class 'total_increasing' which is impossible considering device class ('monetary') it is using; expected None or one of 'total'; Please update your configuration if your entity is manually configured, otherwise report it to the custom integration author.
2023-03-17 07:47:24.471 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: mqtt, zha, sensor.garbage_collection, bmw_connected_drive
2023-03-17 07:47:33.047 ERROR (MainThread) [homeassistant.components.calendar] Entity id already exists - ignoring: calendar.dean_james
2023-03-17 07:47:34.751 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esp32-bluetooth-proxy-office @ 10.0.1.88: Error connecting to ('10.0.1.88', 6053): [Errno 113] Connect call failed ('10.0.1.88', 6053)
2023-03-17 07:47:41.527 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:47:41.529 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:48:21.364 WARNING (MainThread) [homeassistant.components.integration.sensor] sensor.huelight_energy could not restore last state unknown: [<class 'decimal.ConversionSyntax'>]
2023-03-17 07:48:25.156 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: yalexs_ble
2023-03-17 07:48:29.542 ERROR (MainThread) [homeassistant.components.mold_indicator.sensor] Unable to parse temperature sensor sensor.bedroom_temperature with state: unavailable
2023-03-17 07:48:29.546 ERROR (MainThread) [homeassistant.components.mold_indicator.sensor] Unable to parse humidity sensor sensor.bedroom_humidity, state: unavailable
2023-03-17 07:48:29.830 WARNING (MainThread) [homeassistant.components.homeassistant.triggers.numeric_state] Error initializing 'Home - Speedtest Check' trigger: In 'numeric_state' condition: unknown entity sensor.speedtest_download
2023-03-17 07:48:30.838 ERROR (MainThread) [homeassistant.components.automation.home_assistant_update_notifications] Home Assistant - Update notifications: Choose at step 1: On startup, dismiss core and os notifications as they occurred while off: Dismiss core update notification if off: choice 1: Choose at step 3: default: Choose at step 2: Send to first mobile device if specified: Error executing script. Error for device at pos 1: Unable to resolve webhook ID from the device ID
2023-03-17 07:48:31.176 ERROR (MainThread) [homeassistant.components.homekit.util] media_player.plex_plex_for_apple_tv_apple_tv does not support any media_player features
2023-03-17 07:48:31.452 ERROR (MainThread) [homeassistant.components.automation.home_assistant_update_notifications] Home Assistant - Update notifications: Choose at step 1: On startup, dismiss core and os notifications as they occurred while off: Dismiss core update notification if off: choice 1: Choose at step 3: default: Error executing script. Error for choose at pos 2: Unable to resolve webhook ID from the device ID
2023-03-17 07:48:31.905 ERROR (MainThread) [homeassistant.components.automation.home_assistant_update_notifications] Home Assistant - Update notifications: Choose at step 1: On startup, dismiss core and os notifications as they occurred while off: Dismiss core update notification if off: choice 1: Error executing script. Error for choose at pos 3: Unable to resolve webhook ID from the device ID
2023-03-17 07:48:32.287 ERROR (MainThread) [homeassistant.components.automation.home_assistant_update_notifications] Home Assistant - Update notifications: Choose at step 1: On startup, dismiss core and os notifications as they occurred while off: Error executing script. Error for choose at pos 1: Unable to resolve webhook ID from the device ID
2023-03-17 07:48:32.582 ERROR (MainThread) [homeassistant.components.automation.home_assistant_update_notifications] Home Assistant - Update notifications: Error executing script. Error for choose at pos 1: Unable to resolve webhook ID from the device ID
2023-03-17 07:48:32.831 ERROR (MainThread) [homeassistant.components.automation.home_assistant_update_notifications] Error while executing automation automation.home_assistant_update_notifications: Unable to resolve webhook ID from the device ID
2023-03-17 07:48:36.815 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esp32-bluetooth-proxy-office @ 10.0.1.88: Error connecting to ('10.0.1.88', 6053): [Errno 113] Connect call failed ('10.0.1.88', 6053)
2023-03-17 07:49:41.537 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:49:41.541 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:49:51.884 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities climate.hallway_radiator, climate.hallway_thermostat, climate.livingroom_radiator or it is/they are currently not available
2023-03-17 07:51:42.583 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:51:42.585 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:53:26.841 ERROR (SyncWorker_11) [homeassistant.components.unifi_direct.device_tracker] Failed to decode response from AP
2023-03-17 07:53:42.594 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:53:42.597 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:54:46.890 ERROR (SyncWorker_9) [homeassistant.components.unifi_direct.device_tracker] Failed to decode response from AP
2023-03-17 07:55:42.605 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:55:42.610 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:57:43.647 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:57:43.652 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 07:59:43.660 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 07:59:43.663 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:00:56.910 ERROR (SyncWorker_11) [homeassistant.components.unifi_direct.device_tracker] Failed to decode response from AP
2023-03-17 08:01:43.672 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:01:43.678 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:03:44.760 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:03:44.765 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:05:44.776 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:05:44.781 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:07:44.787 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:07:44.790 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:09:45.859 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:09:45.860 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:10:07.722 ERROR (SyncWorker_3) [homeassistant.components.unifi_direct.device_tracker] Failed to decode response from AP
2023-03-17 08:10:27.046 ERROR (SyncWorker_7) [homeassistant.components.unifi_direct.device_tracker] Failed to decode response from AP
2023-03-17 08:11:45.874 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:11:45.879 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:13:45.886 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:13:45.890 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:15:46.929 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:15:46.932 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:17:46.941 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:17:46.947 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:19:46.954 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:19:46.957 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:21:48.038 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:21:48.042 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:23:48.056 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:23:48.060 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:25:48.068 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:25:48.073 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:27:49.148 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:27:49.151 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:28:27.630 ERROR (SyncWorker_8) [homeassistant.components.unifi_direct.device_tracker] Failed to decode response from AP
2023-03-17 08:29:49.159 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:29:49.164 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:31:49.171 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:31:49.175 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:33:50.211 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:33:50.213 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:35:50.221 ERROR (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Unable to connect to the MQTT broker: Connection Refused: not authorised.
2023-03-17 08:35:50.226 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (5)
2023-03-17 08:35:50.853 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities climate.hallway_thermostat or it is/they are currently not available
2023-03-17 08:35:53.670 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:35:55.670 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:35:59.671 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:00.066 WARNING (MainThread) [homeassistant.components.apple_tv] Connection lost to Apple TV "Living Room"
2023-03-17 08:36:01.672 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:03.358 WARNING (MainThread) [homeassistant.components.apple_tv] Connection lost to Apple TV "Office"
2023-03-17 08:36:05.675 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:07.676 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:07.731 WARNING (MainThread) [custom_components.skyq.classes.power] W0010 - Device is not available: Sky Q
2023-03-17 08:36:11.150 WARNING (MainThread) [homeassistant.components.apple_tv] Connection lost to Apple TV "Bedroom"
2023-03-17 08:36:11.679 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:13.680 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:17.682 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:19.684 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:23.687 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:25.687 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:29.689 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:31.691 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:35.692 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:39.694 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:45.699 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:51.703 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:36:53.991 WARNING (MainThread) [switchbot.devices.device] F9-90-6C-9D-B1-95 (F9:90:6C:9D:B1:95): Device unexpectedly disconnected; RSSI: -62
2023-03-17 08:36:56.045 WARNING (MainThread) [switchbot.devices.device] E1-4A-48-D1-7C-BA (E1:4A:48:D1:7C:BA): Device unexpectedly disconnected; RSSI: -68
2023-03-17 08:36:57.705 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:37:03.709 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:37:09.711 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:37:15.713 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
2023-03-17 08:37:19.715 WARNING (MainThread) [homeassistant.components.media_player] Updating huesyncbox media_player took longer than the scheduled update interval 0:00:02
I have pasted as much of the logs as i can but I am unsure where I can look to find logs prior to the restart today to find out the cause of it.
Know the problem could be that you get too many simultaneous queries over the network. Multiple sensors in different integrations can be queried multiple times. E.g. a camera with 3 integrations integrated or double sensors. Or a sensor that is automatically queried by an integratin and by a custom yaml sensor.
In my case, I accidentally created an Mqtt sensor in yaml even though it was automatically queried by an integration.
That does seem logical - but i have no idea where to begin! It is a new install, so I haven’t got everything reinstalled and integrated yet.
I have a lock that has an integration using the wifi but the same sensors are also queried by a Bluetooth integration. Is that the kind of thing you mean?
Yes, that’s exactly what I mean because it will probably be.
Query either way, both will lead to overload in the long run.
