Random restarts of home assistant
Hi. I have been running HA for many years and this is only the second major problem that I have come across with it. I noticed about a month ago that I would see my openHASP displays on. Later I checked and noticed that the Supervisor log had entries warning about Watchdog. Indicating that HA failed and is restarting. Now, it happens several times a day. I am running HA on the Odroid N2+ hardware and I borrowed one from a friend who was not using it at the moment. I did a backup of my setup and restored it to his unit.
It is doing the same thing, so I know that the HW is working.
I have not added any new apps in quite a while and just do the updates as they come in as needed. Below, is a part of the Supervisor log.
2
026-03-18 22:51:48.768 WARNING (MainThread) [supervisor.addons.options] Option 'keyfile' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:51:48.768 WARNING (MainThread) [supervisor.addons.options] Option 'allowed_networks' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:51:48.768 WARNING (MainThread) [supervisor.addons.options] Option 'banned_ips' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:51:48.768 WARNING (MainThread) [supervisor.addons.options] Option 'banlimit' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:51:48.768 WARNING (MainThread) [supervisor.addons.options] Option 'notify_service' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.806 WARNING (MainThread) [supervisor.addons.options] Option 'username' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.806 WARNING (MainThread) [supervisor.addons.options] Option 'password' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'ssl' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'certfile' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'keyfile' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'allowed_networks' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'banned_ips' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'banlimit' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.807 WARNING (MainThread) [supervisor.addons.options] Option 'notify_service' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:56:49.829 WARNING (MainThread) [supervisor.addons.options] Unknown option 'grant' for MariaDB (core_mariadb)
2026-03-18 22:57:26.833 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2026-03-18 22:59:36.310 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_appdaemon] Home Assistant WebSocket API closed
2026-03-18 22:59:36.313 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
2026-03-18 22:59:36.315 INFO (MainThread) [supervisor.api.proxy] [d5369777_music_assistant] Home Assistant WebSocket API closed
2026-03-18 22:59:36.316 INFO (MainThread) [supervisor.api.proxy] [234db91b_everything-presence-zone-configurator] Home Assistant WebSocket API closed
2026-03-18 22:59:45.080 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
2026-03-18 22:59:45.273 INFO (MainThread) [supervisor.docker.manager] Starting homeassistant
2026-03-18 22:59:45.526 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2026-03-18 22:59:54.854 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2026-03-18 22:59:55.055 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'username' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'password' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'ssl' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'certfile' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'keyfile' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'allowed_networks' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'banned_ips' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'banlimit' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.098 WARNING (MainThread) [supervisor.addons.options] Option 'notify_service' does not exist in the schema for File editor (core_configurator)
2026-03-18 22:59:55.109 WARNING (MainThread) [supervisor.addons.options] Unknown option 'grant' for MariaDB (core_mariadb)
I have seen the odd older posts with similar problems and no actual solution(s). I only run a few apps inside HA and others I run in containers.
Thanks.
Andrew
You need to remove all those options from the fie editor app config as they are no longer supported. Probably not the reason for your system’s instability though.
That is unsupported on a HAOS system.
Hi.
Thanks for the tips.
I forgot to clarify that I run other services in Linux containers (lxc) on a Proxmox system mqtt, z2m, influxdb, node-ref.
