I’ve been trying to get my RaspBee II to connect to network from HA. The device works fine when I set it up using the Rasbian Image from Phoscon. It joins the Network and I can pair my Plugs and Light bulb fine. In HA when I go to the deconz webpage via VNC it won’t connect to the network. I’ve tried all the usuall settings and followed the tutorials. The only difference is the Gateway IP in Rasbian comes from my network router, 10.0.0.232 (same IP as the RP5), but in HA it’s 172.30.33.0, which seems to be the default, but won’t join the network. If I try and connect using the 10.0.0.232 IP in HA it still doesn’t work.
