[Raspberry Pi 4 8GB] Error loading the view strategy: TypeError: t[0] is undefined
Error displayed when loading the dashboard:
afbeelding
  • Home Assistant 2023.3.5
  • Supervisor 2023.03.1
  • Operating System 9.5
  • Frontend-versie: 20230309.1 - latest
Configuration check passes
Web Inspector console:
    r 6d296ee5.js:1
    f 6d296ee5.js:1
    g 6d296ee5.js:1
    generateView 6d296ee5.js:1
    o ha-app-layout.js:101
    a ha-app-layout.js:101
    value ha-app-layout.js:101
    performUpdate styles.ts:353
    scheduleUpdate styles.ts:353
    _$Ej styles.ts:353
    requestUpdate styles.ts:353
    u styles.ts:353
    g styles.ts:353
    r ha-app-layout.js:101
    E typography.js:181
    t typography.js:181
    value 6a1bc7e3.js:2
    value 6a1bc7e3.js:2
    setTimeout handler*i/< typography.js:181
    i typography.js:181
    value 6a1bc7e3.js:2
    _$AE styles.ts:353
    _$Ej styles.ts:353
    u styles.ts:353
    g styles.ts:353
    k styles.ts:353
    $ 6a1bc7e3.js:2
    E typography.js:181
    t typography.js:181
    v styles.ts:353
    $ styles.ts:353
    _$AI styles.ts:353
    j styles.ts:353
    update styles.ts:353
    _$Ej styles.ts:353
    set styles.ts:353
    value 6a1bc7e3.js:2
    value 6a1bc7e3.js:2
    _$AE styles.ts:353
    _$Ej styles.ts:353
    u styles.ts:353
    g styles.ts:353
    E typography.js:181
    t typography.js:181
    value 6a1bc7e3.js:2
    value 6a1bc7e3.js:2
    (Async: setTimeout handler)
    i typography.js:181
    (Async: FrameRequestCallback)
    i typography.js:181
    value 6a1bc7e3.js:2
    _$AE styles.ts:353
    _$Ej styles.ts:353
    u styles.ts:353
    g styles.ts:353
    k styles.ts:353
    $ 6a1bc7e3.js:2
    E typography.js:181
    t typography.js:181
    v styles.ts:353
    $ styles.ts:353
    _$AI styles.ts:353
    j styles.ts:353
    _$Ej styles.ts:353
    set styles.ts:353
    value 6a1bc7e3.js:2
    value 6a1bc7e3.js:2
    _$AE styles.ts:353
De bron op ‘http://homeassistant.local:8123/static/fonts/roboto/Roboto-Regular.woff2’ die vooraf was geladen met een koppeling is niet binnen enkele seconden gebruikt. Zorg ervoor dat alle attributen van het preload-label juist zijn ingesteld. 0
De bron op ‘http://homeassistant.local:8123/static/fonts/roboto/Roboto-Medium.woff2’ die vooraf was geladen met een koppeling is niet binnen enkele seconden gebruikt. Zorg ervoor dat alle attributen van het preload-label juist zijn ingesteld. 0
