Raspberry Pi 4 - Home Assistant crashes *a lot*
Hi all,
I have the following setup and versions installed on a raspberry pi 4:
  • Installation method Home Assistant OS
  • Core 2025.12.0
  • Supervisor 2025.12.3
  • Operating System 16.3
  • Frontend 20251203.0
I find that almost every day - I go to my home assistant URL and find that nothing is listening on the port.
I wait a moment 2 minutes - and then refresh again, and the home assistant Server then responds and says that it is starting up.
It will then run for, 1, 2 days, sometimes half a day, and then the same pattern occurs, I find something in my home isn’t behaving right, go to check home assistant, find its not running, me checking if its running seems to start it again, and then the process repeats.
How can I debug this, my thought is that the container must be restarting but I have no idea why, and because the interface I see when booting Home Assistant OS is the container’s CLI for home assistant, I don’t know how to debug what is happening and at what layer.
What do I need to check for more information, so I can provide it to get more help?
Is your SD Card worn out?
What do the logs say?
Any changes since it last worked well? Added devices, new integrations?
Static or dynamic IP Address?
Is it mid update?
