Raspberry Pi 4 want to use large external HD for Plex content
I’m new to Home Assistant and have spent a while doing searches and not sure if I’m using the correct terms as I haven’t found what I’m looking for.
I’m setting up Home Assistant for the first time. Here’s what I have, a Raspberry Pi 4 w/ 8gb ram and a 6tb external powered hard drive. The drive is primarily going to be used as a Plex repository. I did find a post that hinted that maybe I need to put HA on the big drive and then put all of the videos in the media folder. If that is the case, is there an easy way to migrate the current install to that drive or am I back to starting over on the big drive?
If there is a way to find the address of the big drive and add that as the media folder for Plex that would be ideal. I have not reformatted the drive as it is brand new. So if it needs to be formatted, that is not an issue.
Thanks in advance,
James
