Last two days having problems Home assistant keeps dropping out I think it could be an update? Anyone else having the same problem?
Please share your logs. And your definition of “dropping out.”
Does not connect to Homeassistant.local:8123 nor ip
Eventually got it up and running this time it seems more stable
Watch this space…
thanks
Some tips on troubleshooting can be found here (I know your system may not be crashing but it’s still useful info): How to Troubleshoot Raspberry Pi Crashing.
still having the same problem,
my system been running ok for months.
so more likely update broke it
my old system running fine actionstiles.
I have 2x 10.1 touch screen on actiontiles & 2x home assistant
If you want help, share logs.
Raw logs ?
So easy to solve it start again!
been running smart home approx 13 years.
HA long way to go, but getting there.
I’ve been running HA almost 5 years. Never had to restart it to fix it. And it has already come a long way. I considered it “there” years ago.
Again: logs please.
u have smartthings?
show my age first interface was with c64 1984 turning all my individual lights in my bedroom by pressing function keys no wifi
ref problem i think it could be smartthings its keeps on failing 4th time in a week
There seems to be a known issue with smartthings and the latest HA version (2025.3), but a fix should be out soon.
In the meantime, try to reload the integration manually if it’s failing.
when HA becomes more stable plus have more time i will scrap smartthing + hue
thanks
