My HA install went wonky, so I decided to do a fresh install - Straight Raspberry Pi using the Raspberry Pi imaging tool, selecting the Home Assistant OS. Loaded it to an SD card and popped it into my Pi. It throws an error that I have no idea how to fix:
2026-04-15 13:50:56.911 ERROR (MainThread) [supervisor.docker.manager] failed to extract layer (application/vnd.oci.image.layer.v1.tar+zstd sha256:873581ab26511a9d82f5ffea64fe7deb37a19c5692d789862b809fa569dad48d) to overlayfs as “extract-889709374-fp4C sha256:7f53bd8f896f0a10aa155bdeb2a42a4b8c5f94b75dae8693c82d76c2acbc4d7c”: archive/tar: invalid tar header
I have tried re-downloading the imager, different SD cards and it always does this, and then will not load, just cycling on this forever:
2026-04-15 13:55:36.581 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
2026-04-15 13:55:51.586 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
2026-04-15 13:56:06.591 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core installation in progress
I’m running a Pi5 with NVMe. I tested a backup recently with an old SD card and it threw some faults and was very slow. It was more down to the SD card. Some friendly advice, an SD card might not last long. i only get 3/4 months out of mine before it was corrupted. Its the reason i moved to NVMe - i learnt the hard way.
I get that the RPi 5 is small, but for actually less money, especially after case and power supply, a refurbished pc is better value. I have HA running in a Virtual Box under Ubuntu. I have three USB dongles. I see that the RPi recommended power supply is 25W. My installation is pulling 18W. Plus I have the other programs running like SIP (Sustainable Irrigation Platform) a very nice irrigation front end. Also, a UDP translator for extracting the data from my very old solar inverter.
In three years I haven’t had any hardware problems that I didn’t cause.
Extract the .img file from the compressed .xz file you just downloaded
Using Raspberry Pi Imager, insert your SD card and select install a custom image, and choose the HAOS 16.3.img
Once the image is written, put the SD card into your Raspberry Pi and boot it up
Note the local IP address of your installation (format should be similar to 192.168.0.xxx - ignore the /xx at the end), and check the version is 16.3
Open a browser window and navigate to the IP address, with :8123 on the end. Or, you can use http://homeassistant.local:8123
This was an important step for me - ensure the download of the core HA files is not interrupted, by displaying the logs in your browser window. I had to try this 3 times before the files were downloaded correctly, and then I finally saw the welcome screen
Follow the instructions to create an account, and then you should see a notification in the HAOS dashboard that you can update to the latest version.
Thank you! It is good to know that these actually do run at very low power. My RPi3B+ needs 10W (2A) to start, but after that I’m sure it is much less. My one production RPi zero 2w consumes 2-3W
