Hi guys,
I’ve been using an rPi for 2 years now, with a simple raspbian OS, a tsl2591 light sensor and Node-red.
Making the tsl2591 for this setup was quite easy, straightforward, but I wanted to try out the HASS.IO system, and I’m stuck.
How do I go about to be able to communicate to the tsl2591? It’s simply connected to the rpi itself.
I got the latest HomeAssistant system installed, got node-red as addon, but I have no clue as to how to import to this “dashboard” the tsl2591.
PS.: I guess (since I cant verify it yet…), that I successfully enabled the i2c (Common Tasks - Operating System - Home Assistant → SD card method).
Thank you very much for your time,
Take care
