Raspberry Pi with Hassio freeze
I have a Hassio in Raspberry Pi, and, random times, it freeze. Hassio not respond (no Home Assistant, no Samba, no SSH…) and I have reboot it.
How could I check what is the problem?
I check temperature, power consumition and RAM and I not see the problem.
Hi, have you found any solution?
I change the SD and now works fine.
Thx! I’ll try it!
I know it’s a long time ago, but did you change your SD for something similar or you upgraded it?
because I have a similar problème but I already have a 120Go SD card classe 2A so I don’t think I can upgrade more.
I change the SD by other new
yes that I get but did the new one was the exact same as the old one or did it had other spec?
