Raspberry pi zero w wifi setup
Hi
I just loaded raspberry pi zero with hassos_rpi0-w-1.9.img.gz .
How Do i setup wifi configuration.
Is there any way without using extra usb drive.
Naveen
I don’t use my raspberry pi zero w with hassos but with raspbian (headless). This is how I setup my wifi before usage: https://www.raspberrypi.org/forums/viewtopic.php?t=191252. I hope this helps you in the right direction.
I found a solution for this, and I’ve actually opened a new forum topic explaining it - take a look here:
