Raspbery pi 4 can't connect gateway deconz
I’m trying to setup a zigbee network with but some how deconz or even ZHA isnt able to connect to my gate way no matter how i config them. I have two dongle’s one i flash my self a c3125 and the one from sonoff self that should come pre flashed but neither of them work
This is the log i get from deconz some how it sees the dongle but connect to it and keeps retrying.
22:18:50:687 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
22:18:50:711 CTRL. 3.27.222:18:50:998 dev /dev/ttyAMA0
22:18:50:998 COM: /dev/ttyACM1 / serialno: __0X00124B000BE87F1F
22:18:50:998 COM: --dev: /dev/ttyACM1 (ConBee II)
22:18:50:998 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
22:18:51:659 parent process s6-supervise
22:18:51:659 gw run mode: docker/hassio
22:18:51:659 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
22:18:51:659 sd-card cid: 035344534c31364780ffffffff013800
22:18:51:695 DB sqlite version 3.27.2
22:18:51:698 DB PRAGMA page_count: 30
22:18:51:698 DB PRAGMA page_size: 4096
22:18:51:698 DB PRAGMA freelist_count: 0
22:18:51:698 DB file size 122880 bytes, free pages 0
22:18:51:698 DB PRAGMA user_version: 6
22:18:51:698 DB cleanup
22:18:51:700 DB create temporary views
22:18:51:717 don't close database yet, keep open for 900 seconds
22:18:51:720 started websocket server at port 8081
22:18:51:743 found node plugin: libde_rest_plugin.so - REST API Plugin
22:18:51:750 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
22:18:54:833 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
22:18:54:916 dev /dev/ttyAMA0
22:18:54:916 COM: /dev/ttyACM1 / serialno: __0X00124B000BE87F1F
22:18:54:916 COM: --dev: /dev/ttyACM1 (ConBee II)
22:18:55:060 created username: 8FE2467DF1, devicetype: Home Assistant
22:18:56:741 dev /dev/ttyAMA0
22:18:57:509 Announced to internet http://dresden-light.appspot.com/discover
22:18:57:510 discovery server date: Mon, 31 Aug 2020 22:18:57 GMT
22:18:57:510 	 local time seems to be ok
22:18:57:510 discovery found version 2.04.35 for update channel stable
22:18:59:826 don't close database yet, keep open for 900 seconds
22:19:04:729 dev /dev/ttyAMA0
22:19:04:729 COM: /dev/ttyACM1 / serialno: __0X00124B000BE87F1F
22:19:04:729 COM: --dev: /dev/ttyACM1 (ConBee II)
22:19:05:227 device state timeout ignored in state 2
22:19:06:177 device state timeout ignored in state 2
22:19:06:729 dev /dev/ttyAMA0
22:19:06:733 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26580700.bin.GCF
22:19:06:733 GW firmware version: 0x00000002
22:19:07:205 device state timeout ignored in state 2
22:19:08:156 device state timeout ignored in state 2
22:19:09:147 device state timeout ignored in state 2
22:19:10:147 device state timeout (handled)
22:19:10:160 device disconnected reason: 1, index: 0
22:19:10:647 wait reconnect 15 seconds
22:19:10:647 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
22:19:10:647 device state timeout ignored in state 1
22:19:11:647 wait reconnect 14 seconds
22:19:12:646 wait reconnect 13 seconds
22:19:13:646 wait reconnect 12 seconds
22:19:14:146 start reconnect to network
22:19:14:647 wait reconnect 11 seconds
22:19:15:647 wait reconnect 10 seconds
22:19:16:646 wait reconnect 9 seconds
22:19:16:727 dev /dev/ttyAMA0
22:19:17:647 wait reconnect 8 seconds
22:19:18:646 wait reconnect 7 seconds
22:19:19:396 failed to reconnect to network try=1
22:19:19:646 wait reconnect 6 seconds
22:19:20:646 wait reconnect 5 seconds
22:19:21:647 wait reconnect 4 seconds
22:19:22:647 wait reconnect 3 seconds
22:19:23:647 wait reconnect 2 seconds
22:19:24:647 failed to reconnect to network try=2
22:19:24:647 wait reconnect 1 seconds
22:19:24:727 dev /dev/ttyAMA0
22:19:24:727 COM: /dev/ttyACM1 / serialno: __0X00124B000BE87F1F
22:19:24:727 COM: --dev: /dev/ttyACM1 (ConBee II)
22:19:25:218 device state timeout ignored in state 2
22:19:26:168 device state timeout ignored in state 2
22:19:26:734 dev /dev/ttyAMA0
22:19:27:147 device state timeout ignored in state 2
22:19:28:146 device state timeout ignored in state 2
22:19:29:147 device state timeout ignored in state 2
22:19:29:647 try to reconnect to network try=3
22:19:31:146 device state timeout (handled)
22:19:31:154 device disconnected reason: 1, index: 0
22:19:31:646 wait reconnect 15 seconds
I tried plugin them in to a usb calble no luck either even switch every thing from my nas to a new Raspberry PI 4 4GB no luck either. any one had the same issue ?
