RATGDO Update Failure for ESPHome 2025.4.1 "Error binary size: Unknown error from ESP"
I wanted to post this here in case someone runs into the same problem I did. Tried searching for an answer, but couldn’t find much other than the error meaning there was not enough space. I found this odd since I have not had any problems with updates for over a year. After trying a few times with no luck, a thought popped in my head. Maybe the space was low due to cached information on the devices memory. So I figured maybe if I rebooted, my RATGDO would clear its cache and the update would complete.
Well, it worked. After the reboot, I was able to run the update again and the file uploaded successfully and it rebooted as expected. Ran a couple tests and all seems to be working as expected.
I hope if someone else runs into this issue, this will help you out.
Такая же ошибка появлялась. Модуль esp07 после перезагрузки все обновилось. Также были подозрения что память заполнилась мусором.
Confirmed this works. Even a soft-reboot from the HA Device page.
That worked for me. Thank you so much for taking the time to post this. :heart:
