I have a Liftmaster Maxum JHDC model GDO. This is a commercial style opener, as the door is very large and heavy. In the wiring schematic of the RATGDO, it shows two leads to use with these types of openers. RATGDO refers to them as Discrete Open and Discrete Close. That’s all the documentation says. I’m not sure what to do with that. Do I just plug those two leads in parallel with my Wall Control wires? I’m concerned with over-volting the board and frying the RATGDO. Does anyone have any experience with this type of GDO? I have attached some supporting docs of my setup.
I did some playing around with my setup, but was unable to get anywhere.
The Wall Control unit puts out 5-7 vDC. So There seems to be no issue with over volting the RATGDO. However, when hooking the RATGDO in parallel with the WALL CTRL leads, i did absolutley nothing.
So I tried using just a simple 18/2 bell wire using the SBC control, and I got no response as well.
did you ever make progress on this? I haven’t tried to do it yet but I just got a Maxum JHDC installed and was interested in hooking it up to ratgdo.
I’m guessing the commercial wall control unit is significantly more advanced. If it’s the unit with the up, down, and stop buttons, there’s a ton more configuration available there. So my guess is the protocol they are using on those wires is different from the residential openers and that’s why you aren’t able to make it work. With that being said, I am going to try anyway because, why not?
Anyway, if you’ve made any progress, please share!
buy the maxum auxrel board - ~35 online - I picked 2 up on ebay via offer for 40+ shipping.
wire the obstruction sensors like normal - sensor black → ratgdo → maxum
then ratgdo istatus door → open, istatus obst → close
configure the auxrel to have one relay on for close and one on for open and wire those into the open & close limit switches.
GND to common
reflash the ratgdo to dry contact firmware
…profit
without the relay board you’ll only get ‘trigger’ - no state. any other open/close sensors are MINIUM 20/piece and you need two of them. just buy the aux board so the open/close is all maintained in the opener and not separate.
The ‘not closed’ relay for me is the critical piece - so I can turn lights on when the door is opened and start a timer to turn them off when the door is closed if there isn’t anyone in the building.
I never did make any progress on this because I couldn’t find any info on working with these GDO’s and I also got busy with other projects. But now, Thanks to Tongboy above, there is a new direction to try. I absolutely hate the hot garbage that Chamberlain uses for their “App”. It is the absolute worst, and keeps getting worse all the time. So I plan to jump back to this project hopefully in the next few months.,
I assume it’s because Liftmaster is owned by Chamberlain and they don’t like people like us.
I’ve ordered the AUXREL board. I’m gonna try doing my own ESP32 controller to avoid the uncommanded open upon power cycle as noted above. I’ll report back when I have more info.
