Hi Everyone,
I’m keen to know if anyone has the ratgdo working with the B&D Power Drive roller door we get in Australia.
If so, how did you wire up the ratgdo to the B&D, and what security version did you use.
For reference the Power Drive is this one: https://admin.bnd.com.au/media/l1ldtwhl/161082_00-online-quick-setup-guide-rdo-1-1.pdf
The connector on the board is this one:
Here’s a photo of it:
I’ve installed the Security v2 firmware as the v1 firmware reports connections issues.
I used this imgur image to wire up:
My issue is that when I turn everything on, there appears to be some comms, when the ratgdo starts up and the door is active, as the door is moving up and down on its own.
The buttom on the door itself works OK, but no commands from the ratgdo do.
I’m hoping someone has done this and can provide some pointers, thanks.
Peter.
