I’m on 2025.10.2, and it seems the raw configuration editor for dashboard YAML is broken. There’s no color formatting, and Ctrl-F doesn’t function at all. I use this all the time, and I think this is very recent. I have two HA instances, and the issue is the same in both. I’ve refreshed browsers and restarted both instances. I’ve used different browsers, and the problem remains. It’s even present in the HA mobile app. I didn’t see an open issue in GitHub, so I wanted to check if anyone else is experiencing this before opening one. I think I’ve pretty much ruled out something on my end, but maybe not. Anyone else seeing the same thing?
Maybe the same as this ?
Yes, that’s definitely the same issue. Thank you very much. I did not find that for some reason. I will follow the issues there for resolution.
There is an update coming Friday for the fix!
