Razberry with hass.io
Anyone has experience with a Razberry 1 card inside a Pi 3 combined with hass.io?
We have a Razberry installed but it does not want to respond.
The error OZW Log:
2017-06-15 00:29:07.174 Always, OpenZwave Version 1.4.2508 Starting Up
2017-06-15 00:29:20.685 Info, Setting Up Provided Network Key for Secure Communications
2017-06-15 00:29:20.686 Warning, Failed - Network Key Not Set
2017-06-15 00:29:20.686 Info, mgr, Added driver for controller /dev/ttyAMA0
2017-06-15 00:29:20.686 Info, Opening controller /dev/ttyAMA0
2017-06-15 00:29:20.686 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2017-06-15 00:29:20.687 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2017-06-15 00:29:20.690 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-06-15 00:29:20.690 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-06-15 00:29:20.690 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-06-15 00:29:20.691 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-06-15 00:29:20.691 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-06-15 00:29:20.691 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-06-15 00:29:21.691 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-06-15 00:29:21.691 Detail, contrlr, Removing current message
2017-06-15 00:29:21.692 Detail, contrlr, Notification: Notification - TimeOut
2017-06-15 00:29:21.700 Detail,
2017-06-15 00:29:21.700 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-06-15 00:29:22.700 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-06-15 00:29:22.701 Detail, contrlr, Removing current message
2017-06-15 00:29:22.701 Detail, contrlr, Notification: Notification - TimeOut
2017-06-15 00:29:22.701 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-06-15 00:29:23.702 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-06-15 00:29:23.702 Detail, contrlr, Removing current message
2017-06-15 00:29:23.702 Detail, contrlr, Notification: Notification - TimeOut
2017-06-15 00:29:23.703 Detail,
2017-06-15 00:29:23.703 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-06-15 00:29:24.703 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-06-15 00:29:24.703 Detail, contrlr, Removing current message
2017-06-15 00:29:24.704 Detail, contrlr, Notification: Notification - TimeOut
2017-06-15 00:29:24.704 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-06-15 00:29:25.705 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-06-15 00:29:25.705 Detail, contrlr, Removing current message
2017-06-15 00:29:25.705 Detail, contrlr, Notification: Notification - TimeOut
Can’t speak for v1, but I’ve got the Z-Wave Plus version and it works just fine. Is this a known good board - could it be faulty?
It is good board since it working in openzwave.
Could you perhaps share a few lines of your configuration.yaml where you define zwave?
There’s not much to see :wink:
zwave:
  usb_path: /dev/ttyAMA0
  device_config: !include zwave_device_config.yaml
did you get it to work?
