After 6? years I’m finally doing a complete fresh install, (Original Zwave is depreciated and has been removed … I have been putting off migrating for some time)
Current system - RPi 3 B with a Razberry chip running with hass. ~17 zwave devices. I’ve got my system at version 2022.3.6, the newer versions remove the old zwave integration.
I am now faced with a choice…
Options
- Use Razberry chip on a new RPi4 and configure hass / zwave via Zwave JS
- Use a spare RPi3 B+ with the Razberry chip, install Zway-Server. Install hass on the RPi4. Use the Z-Wave.Me integration (connects to a user on the Zway server over the network).
Questions,
- Has anyone experienced both and do you have a preference? If so why?
- I have (just for fun) set it up as option 2 as a test (adding one device), the UI and expert settings of the Zway-server is nice, however I’m not a fan of the way to change configuration parameters of Zwave devices, nor am I a fan of the need to manually name each entity (it seems it is not inherited from the node name)
- Have you seen any errors, delays, missing data etc with using the Z-wave.me integration?
- Segregating the Zwave system from the home assistant instance / RPi beneficial? For data flow I prefer this, but it’s probably not necessary.
Any insight / experience would be appreciated.
