Hi all,
New hassio (107.7) user and trying to get the Razberry2 z-wave controller setup but having some issues. Seems as though the board is detected but then I get an error in the logs. Any ideas why the driver is failing?
2020-03-29 16:30:38.221 Always, OpenZwave Version 1.4.3469 Starting Up
2020-03-29 16:32:34.845 Info, Setting Up Provided Network Key for Secure Communications
2020-03-29 16:32:34.846 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-03-29 16:32:34.846 Info, Opening controller /dev/ttyAMA0
2020-03-29 16:32:34.848 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-03-29 16:32:34.848 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-03-29 16:32:34.849 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-03-29 16:32:34.849 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-03-29 16:32:34.849 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-03-29 16:32:34.849 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-03-29 16:32:34.849 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-03-29 16:32:34.849 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-03-29 16:32:34.850 Detail, contrlr, Notification: DriverFailed
