Hi. I just need to switch between two RCA sources. (2 RCA in and 1 RCA out). Does anyone know of any device that can do this via any protocol? I have looked everywhere and have yet to find something. Thanks in advance.
Your best options are to get one that does switching via IR input and get a IR blaster for HA control or get one with a push button toggle and us a switchbot bot or tuya fingerbot to toggle the source that way.
Hi! Thank you. Any suggestions on an IR blaster? I’m having trouble finding one ![]()
Get the mini if you don’t need the features of the pro.
Ordered to test. Thank you!
If it does not work with the particular switch you want to use it with at least you can use it with other devices that have IR control options for your needs.
I don’t supposed you know of a IR switch by chance? All the ones I’ve found so far are physical knobs.
You are looking for ones like this if you want IR control
This one is the type that would work with a switchbot bot/tuya fingerbot for toggle of the button for switching:
