There is a ESP8266 module with ESPHome firmware. The working firmware code receives the code from the remote radiothermometer in BIN and DEC format. DEC format code is displayed on the homeassistant WEB panel. I need to recalculate the DEC code so that the temperature is readable. Conversion formula (code - 300,000-500 )\10. Tell the guys how to add or correct the code. I know that I need to make changes to the section and then to the function, but I don’t understand how to do this.
esphome:
friendly_name: ESPHome Web 58e44f
min_version: 2025.11.0
name_add_mac_suffix: false
esp8266:
board: nodemcuv2
restore_from_flash: True
preferences:
flash_write_interval: 300s
Enable logging
logger:
Enable Home Assistant API
api:
Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
captive_portal:
one_wire:
- platform: gpio
pin: GPIO2
- platform: dallas_temp
update_interval: 10s
address: 0x5d181e3e31672128
#- platform: dallas_temp
address: 0xDD0000031EFB0428
- platform: adc
pin: GPIO17
update_interval: 2s
unit_of_measurement: “V”
accuracy_decimals: 2
filters:- multiply: 3.27
switch:
platform: gpio
pin: GPIO12
restore_mode: RESTORE_DEFAULT_OFF -
platform: gpio
pin: GPIO14
remote_receiver:
- pin:
number: D3
mode: INPUT_PULLUP
inverted: True
dump: rc_switch
tolerance: 60%
filter: 4us
idle: 4ms
buffer_size: 2kb
on_rc_switch:
#- logger.log:
#format: “on_rc_switch: %i %llu”
#args: [x.protocol, x.code]
then:
- lambda: |-
char str[20];
sprintf(str, “%llu”, x.code);
id(rf_code).publish_state(str);
#- lambda: |-
# ESP_LOGI(“rc_switch”, “Received: %ld, Protocol: %d, Bits: %d”, x.code, x.protocol, x.bits);
#// Здесь можно конвертировать, например, x.code
text_sensor:
icon: “mdi:thermometer”
binary_sensor:
platform: template
device_class: door
platform: remote_receiver
name: “Test Door Open”
internal: true
on_press:
then:
- binary_sensor.template.publish:
state: ON
- switch.toggle: living1 # реле <Relay 1> вкл/выкл одной кнопкой
#- switch.turn_on: living1 # реле <Relay 1> вкл разными кнопками
rc_switch_raw:
code: ‘100001111001000000110001’
protocol: 6
filters:- delayed_off: 100ms
name: “Test Door Close”
internal: true
on_press:
then:
state: OFF
- switch.toggle: living2 # реле <Relay 2> вкл/выкл одной кнопкой
#- switch.turn_off: living2 # реле <Relay 2> выкл разными кнопками
rc_switch_raw:
code: ‘100001111001000000110010’
protocol: 6
