Re-activate a script?
I went to the settings of a Script and disabled the switch “Active”. Now the script no longer shows up under Settings - Scripts. It is still visible in the scripts.yaml. In the scripts.yaml there is no indication for me that the script is not active.
I would now like to revert the setting of the switch “Active” and turn it on again. However, I fail to find the script and go to the scripts settings. Any idea what I need to to? Thanks for your help.
Never tried that, and I was a bit scared to try :slight_smile:
Go to the settings, entities tab. Be sure to disable the filter to hide deactivated entities on the left. Now you can search for it to reenable it.
PS. it sais you need to restart HA, but reloading scripts from the developer tools also returns it to the scripts list.
Perfect - thanks a lot for your help. I didn’t think of a script being an entity.
