how do i add a integration under Esphome back into the Esphome Node screen?
Everything works fine and my node shows up under the integration section. I just cant see if its online in the Esphome node screen.
Anyone know a fix for this?
Did you delete the .yaml file for that device?
i think i have deleted it in the esphome node screen only.
Looking in the config/esphome/ there is no entry for the entitiy.
There is no way to re-create the yaml except from a backup or guessing/memory.
i do have the yaml stored on my pc for future reference.
Can i add that as a new file in config/esphome, or do i need to make a new node and paste it in there?
Just move the file to config/esphome
thank you!, that worked. Just had to make sure that the name of the file is also excatly the same as the integrations name.
