Using a Cielo device to control an ac in the electric room.
It is set to turn on if the temp goes above 27 and off when it goes below 25 (°C if you did not guess already)
It works fine most of the time but every now and then the Cielo thinks it sent a command, or it did and the ac ignored it, or whatever. Point is it either did not turn on or off and the Cielo now has the wron ac state.
If it did not turn on, the room just keeps getting warmer and if not off, well… it gets pretty darn cold and uses a lot of electricety.
So I came up with an automation, two actually.
One that triggers when it gets too hot and one for too cold, but even here the Cielo at times messes things up so I would like to re-evaluate the trigger (temerature in this case) and trigger the automation again if needed.
For the moment I added extra temperatures to trigger it, just seems so clunky. Is there a better way you can suggest?
For too cold
Before you ask, i have to send the ‘turn on’ command so the Cielo will accept the ‘turn off’ command, else it ignores it as it is already in the ‘off’ state
Which I leave on top of the AC unit, it’s not perfect, but if it stays on for a while (when it shouldn’t) or isn’t on when it should be, I send the power command again.
Since putting in the sensor and accompanying automation, I haven’t had the AC running away.
First thing is that will only trigger when it transistions from one state to another, E.G. when it goes from 26 to 27, it will trigger if its already at 28 it not trigger so use numeric state with no temp settings to trigger and condition with the temperature.
Although this is exactly what the generic thermostat is designed to do. and would be easier to use.
It literally just happened (IR got blocked) it fixed itself in about 1 minute - much quicker than monitoring the temperature.
Additionally when it’s really hot, the AC stays on constantly - it isn’t able to keep up, so I need an actually feedback mechanism to know that its really on.
In previous threads I have asked about monitoring the power consumption however, so far I haven’t found a smart plug for a 220V US socket (that the AC uses).
Monitoring the power is not possible, wired straight into the breaker box and inside conduits.
I was thinking of using a power clamp but the breaker box is a mess and full, rather stay away
The ac does have a port for a wifi dongle but have not investigated that. Too many other projects. It would however be the best if it gives feedback on its state.
For mow, I think I will stay with what I have, it works.
What is the make/model of the AC unit? What does this wi-fi port looks like? I recall seeing people doing some wi-fi dongle thing on their Midea or Toshiba or Panasonic units - you might get lucky searching Github.
====== sidebar ======
Specifically regarding this:
So if power monitoring means would not work for you, maybe… depends on the style of your AC unit, this might also help if your AC has a motorized cover that would flap open when on (common for those non-central AC setups). And then some regular door/window sensor could see whether your AC is on.
