I am running home assistant in Docker on a vps.
I am happy with this configuration and with the appropriate components I can do almost anything.
At home I have a rpi 1 version.
The server and the rpi communicate each other using zerotier; indeed some of my custom home sensor send data to rpi and it will forward them to mqtt running on the vps.
The problem is that i have some devices e.g. chromecast and yeelight which can be only used with a direct connection, using their ip.
So, i’d like to access them from the server.
The proper way is to configure rpi as a zerotier bridge, but I tried and it didn’t work (I mean the bridge).
Do you have any solution?
It is possibile to tell home assistant to reach just some device using a proxy (so, the rpi)?
Thanks.
