Hier mal mein Beispiel.
modbus:
- name: "DaheimLader"
type: tcp
host: 192.168.1.37
port: 502
timeout: 60
sensors:
# --- Status-Register (kein Scale) ---
- name: "DaheimLader Status"
address: 0
scan_interval: 30
data_type: uint16
unique_id: daheimLader_charging_station_state
- name: "DaheimLader Status Ladekabel"
address: 2
scan_interval: 30
data_type: uint16
unique_id: daheimLader_cable_state
- name: "DaheimLader Fehlercode"
address: 4
scan_interval: 30
data_type: uint16
unique_id: daheimlader_fault_code
# --- Ladestroeme pro Phase (Factor 0.1) ---
- name: "DaheimLader Ladestrom L1"
address: 6
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unit_of_measurement: A
device_class: current
state_class: measurement
unique_id: daheimlader_l1_charging_current
- name: "DaheimLader Ladestrom L2"
address: 8
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_l2_charging_current
- name: "DaheimLader Ladestrom L3"
address: 10
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_l3_charging_current
# --- Leistung (kein Scale, uint32) ---
- name: "DaheimLader Ladeleistung"
address: 12
scan_interval: 30
data_type: uint32
unit_of_measurement: W
device_class: power
unique_id: daheimlader_active_power
- name: "DaheimLader Ladeleistung L1"
address: 16
scan_interval: 30
data_type: uint32
device_class: power
unique_id: daheimLader_l1_charging_power
- name: "DaheimLader Ladeleistung L2"
address: 20
scan_interval: 30
data_type: uint32
device_class: power
unique_id: daheimLader_l2_active_power
- name: "DaheimLader Ladeleistung L3"
address: 24
scan_interval: 30
data_type: uint32
device_class: power
unique_id: daheimlader_l3_active_power
# --- Energiezaehler (Factor 0.1!) ---
- name: "DaheimLader Zaehlerstand"
address: 28
scan_interval: 30
data_type: uint32
scale: 0.1
precision: 1
unit_of_measurement: kWh
device_class: energy
state_class: total_increasing
unique_id: daheimLader_energy_meter
# --- EVSE Limits (Factor 0.1) ---
- name: "DaheimLader EVSE Max Strom"
address: 32
scan_interval: 60
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_evse_max_current
- name: "DaheimLader EVSE Min Strom"
address: 34
scan_interval: 60
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_evse_min_current
- name: "DaheimLader Kabel Max Strom"
address: 36
scan_interval: 60
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_cable_max_current
# --- Geladene Energie Session (Factor 0.1) ---
- name: "DaheimLader Geladene Energie"
address: 72
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
state_class: total
unique_id: daheimLader_charged_energy
# --- Ladedauer ---
- name: "DaheimLader Ladedauer"
address: 78
scan_interval: 30
data_type: uint32
unit_of_measurement: s
device_class: duration
unique_id: daheimlader_charging_time
# --- Safe Current (Factor 0.1) ---
- name: "DaheimLader Safe Current"
address: 87
scan_interval: 60
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_safe_current
# --- Ladestrom Limit (Factor 0.1) ---
- name: "DaheimLader Ladestrom Limit"
address: 91
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_limit_charging_current
# --- Steuerung ---
- name: "DaheimLader Modus"
address: 93
scan_interval: 30
data_type: uint16
unique_id: daheimlader_charge_control
- name: "DaheimLader Charge Command"
address: 95
scan_interval: 30
data_type: uint16
unique_id: daheimlader_charge_command
# --- Echtzeit-Spannungen (Factor 0.1) ---
- name: "DaheimLader Spannung L1"
address: 109
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unit_of_measurement: V
device_class: voltage
unique_id: daheimlader_l1_voltage
- name: "DaheimLader Spannung L2"
address: 111
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_l2_voltage
- name: "DaheimLader Spannung L3"
address: 113
scan_interval: 30
data_type: uint16
scale: 0.1
precision: 1
unique_id: daheimlader_l3_voltage
# --- Switches ---
switches:
- name: "DaheimLader Charging Enable"
unique_id: daheimlader_charging_enable
address: 100
write_type: holding
command_on: 1
command_off: 0
verify:
address: 100
input_type: holding
und mein Dashboard
title: DaheimLader Wallbox
icon: mdi:ev-station
- title: Wallbox
path: wallbox
type: sections
max_columns: 2
sections:
- title: ''
cards:
- type: markdown
title: Station Status
content: >
{% set status_map = {
0: 'Standby',
1: 'Bereit',
2: 'Verbunden',
3: 'Laden startet',
4: 'Laedt',
5: 'Start fehlgeschlagen',
6: 'Laden beendet',
7: 'Systemfehler',
8: 'Ladetimer',
9: 'Firmware Upgrade',
10: 'Eingeschaltet',
31: 'Blockiert'
{% set cable_map = {
0: 'Nicht verbunden',
1: 'Verbunden'
{% set fault_map = {
0: 'Kein Fehler',
11: 'CP-Kontroll Wert',
13: 'Unterspannung',
14: 'Ueberspannung',
15: 'Temperatur zu hoch',
16: 'Zaehlerwert',
17: 'Leckage',
18: 'Output Short',
19: 'Ueberstrom',
21: 'Fahrzeug',
22: 'Fahrzeug nicht erkannt',
23: 'Relais',
24: 'Leckage, Geraet pruefen',
25: 'PE-Fehler',
26: 'Start/Stopp Ladefehler'
{% set s = states('sensor.daheimlader_status') | int(0) %}
{% set c = states('sensor.daheimlader_status_ladekabel') | int(0)
{% set f = states('sensor.daheimlader_fehlercode') | int(0) %}
{% if s == 4 %}**Status:** ⚡ {{ status_map.get(s, 'Unbekannt') }}
{% elif s in [1, 10] %}**Status:** 🟢 {{ status_map.get(s,
'Unbekannt') }}
{% elif s in [5, 7, 31] %}**Status:** 🔴 {{ status_map.get(s,
'Unbekannt') }}
{% elif s in [3, 8] %}**Status:** 🟡 {{ status_map.get(s,
'Unbekannt') }}
{% elif s == 0 %}**Status:** ⚪ {{ status_map.get(s, 'Unbekannt')
{% else %}**Status:** 🔵 {{ status_map.get(s, 'Unbekannt (' ~ s ~
{% endif %}
{% if c == 1 %}**Ladekabel:** 🟢 {{ cable_map.get(c) }}
{% else %}**Ladekabel:** ⚪ {{ cable_map.get(c, 'Unbekannt') }}
{% endif %}
{% if f == 0 %}**Fehlercode:** ✅ {{ fault_map.get(f) }}
{% else %}**Fehlercode:** ⚠️ {{ fault_map.get(f, 'Code ' ~ f) }}
{% endif %}
- type: entities
show_header_toggle: false
entities:
- entity: switch.daheimlader_charging_enable
- type: gauge
entity: sensor.daheimlader_ladeleistung
unit: W
min: 0
max: 11000
needle: true
segments:
color: '#0d9488'
color: '#22d3ee'
color: '#a78bfa'
color: '#f59e0b'
- type: markdown
title: Aktuelle Session
content: >
{% set t = states('sensor.daheimlader_ladedauer') | int(0) %}
{% set h = (t // 3600) %}
{% set m = ((t % 3600) // 60) %}
{% set sec = (t % 60) %}
{% set dauer = '' %}
{% if h > 0 %}{% set dauer = h ~ 'h ' %}{% endif %}
{% if m > 0 %}{% set dauer = dauer ~ m ~ 'min ' %}{% endif %}
{% set dauer = dauer ~ sec ~ 's' %}
🔋 **Geladen:** {{ states('sensor.daheimlader_geladene_energie')
}} kWh
⏱️ **Ladedauer:** {{ dauer }}
📊 **Zaehlerstand:** {{ states('sensor.daheimlader_zaehlerstand')
}} kWh
- type: glance
title: Netzspannung
show_state: true
columns: 3
entities:
- entity: sensor.daheimlader_spannung_l1
- entity: sensor.daheimlader_spannung_l2
- entity: sensor.daheimlader_spannung_l3
- title: ''
cards:
- type: horizontal-stack
cards:
- type: gauge
entity: sensor.daheimlader_ladeleistung_l1
unit: W
min: 0
max: 3700
needle: true
segments:
color: '#22d3ee'
color: '#0891b2'
color: '#f59e0b'
- type: gauge
entity: sensor.daheimlader_ladeleistung_l2
unit: W
min: 0
max: 3700
needle: true
segments:
color: '#a78bfa'
color: '#7c3aed'
color: '#f59e0b'
- type: gauge
entity: sensor.daheimlader_ladeleistung_l3
unit: W
min: 0
max: 3700
needle: true
segments:
color: '#34d399'
color: '#059669'
color: '#f59e0b'
- type: glance
title: Ladestroeme
show_state: true
columns: 3
entities:
- entity: sensor.daheimlader_ladestrom_l1
- entity: sensor.daheimlader_ladestrom_l2
- entity: sensor.daheimlader_ladestrom_l3
- type: markdown
title: Wallbox Limits
content: >
**EVSE Max:** {{ states('sensor.daheimlader_evse_max_strom') }} A
· **EVSE Min:** {{ states('sensor.daheimlader_evse_min_strom') }}
A
**Kabel Max:** {{ states('sensor.daheimlader_kabel_max_strom') }}
A · **Strom Limit:** {{
states('sensor.daheimlader_ladestrom_limit') }} A
**Safe Current:** {{ states('sensor.daheimlader_safe_current') }}
A · **Modus:** {{ states('sensor.daheimlader_modus') }}
- type: history-graph
title: Leistungsverlauf
hours_to_show: 24
entities:
- entity: sensor.daheimlader_ladeleistung
- entity: sensor.daheimlader_ladeleistung_l1
- entity: sensor.daheimlader_ladeleistung_l2
- entity: sensor.daheimlader_ladeleistung_l3
- type: statistics-graph
title: Energieverbrauch
entities:
- entity: sensor.daheimlader_zaehlerstand
days_to_show: 30
stat_types:
- change
chart_type: bar
period: day
- type: conditional
conditions:
- condition: numeric_state
entity: sensor.daheimlader_fehlercode
above: 0.5
card:
type: markdown
title: Fehler aktiv
content: |
16: 'Zaehlerwert',
17: 'Leckage',
18: 'Output Short',
19: 'Ueberstrom',
21: 'Fahrzeug',
23: 'Relais',
25: 'PE-Fehler',
**Code:** {{ f }}
**Beschreibung:** {{ fault_map.get(f, 'Unbekannter Fehler') }}
Bitte Wallbox pruefen und ggf. Fehlerspeicher zuruecksetzen.
