I am creating a TTS message to have alexa repeat back an entity id. How to setup the code to have it read the minutes part only? The duration is 00:40:00. Alexa play back the code below as
@123
I applied this to another automation I have where I want Alexa to read 30.1 (omitting the last digit) and NOT 30.11. Testing the code seems to work; however, the formatting seems to be off. The screenshot below shows half of the code is blue and abruptly turns to normal text.
Ignore it. It is an error with the syntax highlighter. It thinks anything with a colon in it is a key: value pair. This is only cosmetic and will not affect your message.
