Hi All,
I recently switched from 2-point thermostat climate plaform to PID Climate. To evaluate the control parameters i want to read the heat output in Home Assistant. At the moment I can’t see the values weather in the ESP Home log, nor as a entity in HA.
climate:
- platform: pid
name: "Thermostat Wohnzimmer"
sensor: temperatur_wohnzimmer
default_target_temperature: 21°C
heat_output: WZ_heater_pwm
control_parameters:
kp: 0.49460
ki: 0.00487
kd: 12.56301
output_averaging_samples: 5 # smooth the output over 5 samples
derivative_averaging_samples: 5 # smooth the derivative value over 10 samples
deadband_parameters:
threshold_high: 0.2°C # deadband within +/-0.5°C of target_temperature
threshold_low: -0.2°C
output:
- platform: slow_pwm
pin: GPIO4
period: 30min
