I am currently trying to integrate a OXRS device (https://oxrs.io/) that communicates via JSON over mqtt. I am using this to read the state of switches and sensors connected to the device.
When a switch or sensor is triggered it sends something like the following to a single mqtt topic:
"port": 5,
"channel": 1,
"index": 17,
"type": "contact",
"event": "closed"
In this example I am interested in the “type” and “event” information only if “index” = 17. If “index” does not equal 17 then the message should be ignored.
My question is - How do I first check to see if “index” is equal to 17 before reading the “type” and “event” values?
Thank you
