Yesterday upgrated my config to HASSOS 3.7 because wanted to boot from USB instead of SD. Everything was fine, except when I click (in Hass.io… SYSTEM menu) the button REBOOT. This simply shutdown my RPI3+. I have to unplug it and replug it in order to reboot.
BUT when I launch the command
hassio homeassistant reboot
from putty, it works fine. Did someone experience the same problem?
Anybody else has this problem?
Going on hass.io menu, then SYSTEM tab, then clicking on REBOOT makes my RPI3+ to shutdown. I have to manually unplug and replug power.
Host system HassOS 3.7
Hassio supervisor 193
Home Assistant 0.103.6 Booting from USB, without SD iserted, this may causes the problem??
