Reboot OS Docker Starts but config is gone. Have to start from scratch again
Reboot OS Ubuntu Docker Starts but HA config acts like its gone when navigating to the we UI. Appears I Have to start from scratch again. Logs / config all look like they are there. This is the third time I ran into this. Anyone run into this that has figured out why?
Are you trying to get to the web interface via the machine IP and port?
If so then do you have that HA machine set up with a fixed IP address somehow? Either in your router or in the config of the machine?
If not then you might be getting a different IP so it only looks like it’s gone.
HI, Nope I am using IP:Port… The Config is gone everytime I reboot. The Server has a static IP.
docker or docker compose? If you have docker-compose.yml file it is docker compose. Very similar probably identical.
You can post your config file for home assistant here without any passwords or such.
