Very frustrating, I got everything configured and restarted the HAOS server. When I did, none of the integrated devices that were automatically detected when I originally installed HAOS work now. Specifically LIFX, TP-Link and Wiz devices all return an error now. The LIFX devices aren’t even connected to the LIFX app anymore! SOME devices work through the Tuya integration and others not. What happened and how do I undo this? It was all working perfectly and all I did was unplug the server and plug it back in. Please help, so many hours of work in jeopardy…
Did You ? , Or did you Restart ?
What do you mean by unplugged? Network Cable, Power Cable, USB Dongle or Phone logged in? Crystal Ball is not working?
Oh and what hardware here to and VM if used?
I initally unplugged it to move it to its final location. Home Assistant is back up and some devices are visible there, but all of the auto-detected integrations are broken. These devices are also now unavailable through their native apps.
Oh boy, you should’ve done a shutdown before moving.
I’m running HAOS on an intel n97 minipc with an ethernet connection to the LAN. Everything was working before I unplugged and restarted the server, and then the auto-detected integrations failed and retry endlessly. After i removed the devices the integrations disappeared from the list in Devices and Services, but when trying to re-add the intregrations no devices are detected now. The devices are also no longer available in their native apps which I’ve never seen before.
Try manual detection of one devices under a integration. Also “an ethernet connection to the LAN” has not definitive enough. Clearer would be wired 1G or wireless 2.5, 5, or 6 GHz connection. All are consider a ethernet connection back to LAN really
Apologies. It is an hardline CAT6 1Ghz ethernet connection to the router.
When attempting to add an LIFX bulb by its IP address it says “failed to connect.” It appears that LIFX TP-Link, and Wiz brand devices–which were all autodetected when HAOS was first installed–are all inaccessible now from either HAOS or their native apps.
ESPhome is also broken, can’t see or connect to devices.
Try a reset of a device, unplug power source for 5 minutes. Plug it back in while watching for it, both at your router GUI and HA integration for it. There may be a reset button on some, others check the documentation on how to reset or remove a device (even the phone app).
I’m adding this:
Looks like your network is borked. Did you somehow turn on a DHCP server, or shut one off? Is you cable plugged into the the right port?
