I am using Home Assistant 2022.4.5 as a virtual machine. I added Grafana and Influx and it is working really nice so far.
Now I want to have two data sources in a single graph. One ranges from 0 to 1 and the other from 0 to 100. Obviously the first one is not good to recon…I would like to do a “divide by 100” for the second so both can be seen properly in the graph.
I checked for Grafana to do recalculation and found something like transformation but did not succeed in understanding if this helps.
Anyone having a clue how to do?
And no, I do not want to do the calculation in HA as it should get the correct value…
ok, working, too. MEanwhile I found the way to do the calculation. I am surprised it appears to be so easy. Just add the math to the SELECT statement. See below:
