So a few weeks ago I started getting a significant delay when executing a script that turns off 4 Z-Wave switches at the same time. I’ve not noticed more than 1-2 seconds in the past (system has been up for ~9 months), but this is taking 4-8 seconds (possibly 16 according to a log entry I noticed).
I tried adding 0.1 second delays to the command, however it doesn’t seem to have made a difference. I still see the following error log entries that stand out to me:
Start of command:
2025-02-11T21:20:22.639Z DRIVER » [Node 006] [REQ] [SendDataBridge]
First error @ almost 3 seconds - these or similar repeat for 2 seconds
2025-02-11T21:20:25.473Z DRIVER Dropping message with invalid payload
2025-02-11T21:20:25.473Z DRIVER « [Node 010] [REQ] [BridgeApplicationCommand]
│ RSSI: -76 dBm
└─[Security2CCMessageEncapsulation] [INVALID]
error: Duplicate command (sequence number 255)
A different error at almost 5 seconds
- 2025-02-11T21:20:28.161Z CNTRLR [Node 003] failed to decode the message, retrying with SPAN extension…
There are a bunch more of the invalid payload errors, and then @ 19 seconds we get:
2025-02-11 13:20:41.345 ERROR Z-WAVE-SERVER: The node failed to decode the message. (ZW1405)
ZWaveError: The node failed to decode the message. (ZW1405)
at Driver.sendMessage (/snapshot/build/index.js:275348:25)
at Driver.sendCommandInternal (/snapshot/build/index.js:275472:31)
at Driver.sendSupervisedCommand (/snapshot/build/index.js:275497:29)
at Driver.sendCommand (/snapshot/build/index.js:275525:34)
at Proxy.set (/snapshot/build/index.js:225089:24)
at Proxy.set (/snapshot/build/index.js:224869:34)
at Proxy.<anonymous> (/snapshot/build/index.js:225128:23)
at ZWaveNode3.setValue (/snapshot/build/index.js:278424:44)
at NodeMessageHandler.handle (/snapshot/build/index.js:291556:37)
at Client.receiveMessage (/snapshot/build/index.js:292920:92)
What I’ve tried so far:
- updated Z-Wave JS UI to current (zwave-js-ui: 9.30.1, zwave-js: 14.3.8)
- updated HA Core to 2025.2.2
- individually Rebuilt Routes and for the whole network, multiple times.
- tried assigning priority routes to bot a few, and most hardwired nodes in an order that seemed to make sense to me (all cleared now (except 2 as it didn’t seem to help)
How should I troubleshoot this further?
Thanks in advance!
Here’s the script I ran, nothing special
Script
sequence:
- action: light.turn_off
metadata: {}
data: {}
entity_id:
- light.living_room_hall_cans
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 100
metadata: {}
data: {}
entity_id:
- light.living_room_cans
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 100
metadata: {}
data: {}
entity_id: light.dining_room_chandelier_group
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 100
metadata: {}
data: {}
entity_id:
- light.bar_pendants
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 100
metadata: {}
data: {}
entity_id:
- light.kitchen_cans
alias: Turn off Main Floor Lights w/Delays
description: ""
And finally, the raw log for the command from Z-Wave JS UI Debug:
