At my old home, this worked fine. Since arriving at my new home, I’ve been having some difficulties with Home Assistant though. I can’t access the external URL regardless of device or connection (e.g. laptop on ethernet and phone on mobile).
To be clear, I can still access other things (e.g. Jellyfin, which I host using the Home Assistant add-on) using my DDNS and Nginx Proxy Manager, so it’s not an issue with either of them. There’s something going on weird with my Home Assistant install specifically
I already have the following in my configuration.yaml:
http:
use_x_forwarded_for: true
trusted:proxies:
- 172.30.33.7
- 172.30.33.0/24
I checked my log and do have a “A request from a reverse proxy was received…” error, and the internal IP is the same as the above.
I’ve tried restarting Home Assistant, but the problem persists.
I should not that hardware-wise, the only change to my setup with moving is that I got a new router.
I am using Home Assistant OS.
What am I doing wrong?
